I decided to modify my Compadre and add coil connector - mostly because of this annoying assembling procedure (I like to put my Compadre in backpack) when you have to turn whole pole trying to wrap the cable around it. I tried to find original Switchcraft connector but had no luck, so I used regular Radioshack 4-pin audio connector. It works fine, but when I touch its metal body Compadre beeps, so it has to be grounded to avoid this noise. After grounding it works well.
Just in case I measured this original Compadre's 7" coil and data was slightly different from standard Tesoro coils published on this forum couple months ago.
My Compadre coils has:
TX: 5.64 mH, 20 Ohm
RX: 5.88 mH, 30 Ohm
RX and TX coils have common ground (RX- and TX- wired togedher INSIDE coil body), so all these discussion about "if schematic with grounded Rx is wrong" doesn't make sense
TX: 5.64 mH, 20 Ohm
RX: 5.88 mH, 30 Ohm
