Hello,
I create a new post after exchanges from here :
http://www.geotech1.com/forums/showt...194#post165194
I want to increase the sensitivity of CS4PI to detect small gold nuggets in highly mineralized ground.
A coil smaller than 6.5 inches (154mm) with 0.5 mm wire gives better results than the original coil.
j'ai augmenté
I increased the original 4 Mz quartz frequency with a 6 Mz, with the original coil the results are very good in the air but very disappointing on the ground, we must excessive reduce the power to find correct ground effects management .
What's happening, why this problem with the original coil? Is it an capacitor effect?
So I will make a faster coil.
To understand this detector, I drew the 4pi schematic, there may be some minor errors, it remains to put the components value, but you can see the principle of operation.
j'ai augmenté
