Delta Pulse
  • ok
    agradeço sua resposta.
    • Delta pulse help
      Dear friends
      I read md4u forum about this delta pulse schema is not correct.
      some connection is false.İf so ivconic or geo could sent near photo about
      delta pulse.
      below link about above subject.
      http://forum.md4u.ru/viewtopic.php?t...fd8766216cccfa
      I am trying thirt delta pulse but not succes.
      Best Wishes
      Erol
      • I have sent photos here. Anyway how near photos would you like to send here ????
        • Hi all,
          friends this is my delta pulse with lcd project. Do you like it?
          • What do you read with LCD ??
            • My project is in design level now. I read first 250uS after pulse from lcd.
              I'm Turkish. This site is our detector forum :
              http://forum.donanimhaber.com/m_3925..._5/key_/tm.htm
              If you want, you can look at this forum.
              My nick is elbombaci in this forum.
              Sincerely...
              • hello all
                Schema and pcb is correct.
                I built DP it is Working .
                Best Wishes
                Erol
                • deltapulse working
                  hello all
                  Best Wishes
                  Erol
                  • Originally posted by fish1985 View Post
                    Sincerely...
                    Hi Fish1985.
                    If you read right the fall pulse then you can do a typical discrimination for small and medium size objects.
                    • treiti
                      en
                      I have found mistakes when compared distributings it:
                      1- R33 sat on a path 10 leg U10 - 2 leg U7, небыло crosspieces between
                      2- and 6 leg 555.2 æ16 it is connected to a path 2,5 leg U6-R27, C11 it is not connected with 4 leg U4
                      rus
                      ошибки я нашел когда сравнивал разводки это:
                      1- R33 сидел на дорожке 10 нога
                      U10 - 2 нога U7,
                      небыло перемычки между 2 и 6 ногой 555.
                      2- С16 соединен с дорожкой 2,5 нога U6- R27,
                      C11 не соединен с 4ой ногой U4.
                      http://thunting.com/geotech/forums/a...2&d=1162692174
                      http://thunting.com/geotech/forums/a...3&d=1162692516
                      ошибок нет
                      Mistakes are not present
                      http://www.treiti.times.lv/shem/deltapi_v1_treiti.zip
                      treiti
                      • Hi all. Schematics of Delta Pulse and XR71p are right . Pcb from XR71p is ok and tested . Another pcb for DP that you can find at this forum is ok except one jump that you must put at pin2 and pin6 of 555 (audio). I don't know about the pcb that KT315 send here.
                        • Gate Driver Waveform
                          Hi all,
                          I checked the gate drive...(Voltage is from source to gate)
                          I think it is not good. How about your gate drive waveform?
                          Thanks in advance.
                          • can delta pulse work with 6V 4.5A battary.
                            can this battery drive all components ?
                            can it cause any problem?
                            • Originally posted by okantex View Post
                              Hi okantex,
                              I think that could be fine to have 6V battery instead of 12v.
                              Never tested but think that could be ok...just I see a possible problem on Vgson of mosfet device...
                              6 volts are not big voltage for a mosfet to be turned fully on but think that would be fine for many types including IRFs.
                              If I remember well Vgson for most IRFs is around 4volts, but the higher the better.
                              Another issue is current peak...but cause of inductance of coil in PIs this is not generally speaking a big issue related to Vcc.
                              You could have problems on op amps supply but can find low voltage types that would be fine if you encounter that.
                              For cmos and 555 6v are fine for everything.
                              Good luck.
                              Best regards,
                              • Hi All.
                                Delta Pulse don't work with 6V. It has in series with power suply two diodes so the voltage will be 6-1.2=4.8V,very low voltage. If you modify the circuit.... who knows...maybe to work. When the voltage is lower than 9V the detector is unstable and has very low sensitivity.
                                Bye
