Hello,
I found very interesting, to analyse the flat spiral coil. Especially the effects on the flattening and the weakening the magnetic fields.
The spiral coil has a starting radius (20 mm in this example) and an ending radius (80 mm in this example) with 50 windings.
Figure below shows the magnetic fields strength and directions on a half cross section of the coil. Red elements are the coil wire elements with showing the current direction. Black vectors are magnetic fields (H-Field).
http://imgbox.de/users/zet/spiral1.gif
By reducing the complexity of the coil for a better view (reducing the number of windings), you can see, why flat spiral coils are not effective. Between each two windings there occur canceling regions. The generated magnetic field from the outer winding will be slightly cancelled by the next inner winding. Also, this causes the flattening of the magnetic fields above the coil. See below picture for more details.
http://imgbox.de/users/zet/spiral4.gif
The detailed result is shown on the next picture:
http://imgbox.de/users/zet/spiral3.gif
The next picture shows two flat sprial coils with different diameters (same winding direction). The inner coil is driven with 0.4 A and the outer with 0.1 A current to show the canceling field better.
http://imgbox.de/users/zet/spiral2gif
to be continued..
to be continued..
