i want to take the output and send it to micro controller
but it must be above 2.5volt for the micro controller to sense it
i wanna change the output of the metal detector to 5volt
ROBOT
mine detecting robot
if there is a mine the robot should stop
that's why i want 5v signal from the metal detector
if the micro controller sense the 5v it will stop the motors and do some other stuff
robot----- What size robot that will carry all?(pcb MD+ coil+ pcb main+,,,,)
Usually with a robot carries light like Sensors,,,,in our case things like Pinpointer .
In any case you need a new design project.
best time
j.
