Originally posted by Carl-NC
View Post
Bipolar PI design
Originally posted by Carl-NC View PostYou will never be able to match the P and N drive of a half-bridge driver. To get the Rds to match, the PMOS needs to be much larger than the NMOS. Then the parasitic capacitance of the PMOS will be much larger and the damping will be different for the P & N. You can fake it somewhat by adding series resistance or extra capacitance to the FETs.
Serious conversation is how the difference in Rds on and Cds between P-ch and N-ch transistors will affect the real work in practice. It is good to make this:
1. Adding of external resistors (this reduce the difference). The resistor in drain of N-ch transistor have to be with higher resistance.
2. Adding of capacitor in parallel to TX coil.
3. Use serially connected fast diodes with very low capacitance in series of the transistors
All these thinks have to seriously reduce imbalance. Maybe some one have possibility to analyze these ideas with good software simulator.
Originally posted by Detectorist#1 View PostSerious conversation is how the difference in Rds on and Cds between P-ch and N-ch transistors will affect the real work in practice. It is good to make this:
This is taught in first grade.
You're posing like a fairground vendor.
Hi, Carl, can you take a look at whether this source code will work correctly for half-sine, I made it for PIC16F18426Attached Files
Originally posted by algan View PostHi, Carl, can you take a look at whether this source code will work correctly for half-sine, I made it for PIC16F18426
