The solution - desolder all resistors and sold them in right direction! But not today. We have to believe in tomorrow's day!
Bipolar PI design
Now seriously,
Ivconic, for your dream for good MD, capable to finding small coins, with good GB possibilities, not with very deep possibilities, maybe mechanically stable coplanar PI-IB coil will do this work. All we, DIY peoples, have to make additional efforts for achieve this dream.
- Likes 1
I totally agree with you, Detectorist #1. My next project will be a hybrid detector with an IB DD coil. I'm about to buy a Hybrid Pulse from Mikron Bulgaria to see how it works and maybe improve it. I'm sure we could solve the ground balance issues with this detector together with an LM393 comparator. I have a friend here in Spain, in a city called Huelva, who has a detector like this, and he told me that it's practically impossible to search in real ground with this detector. The ground balance is impossible to adjust; you'd have to adjust the ground balance every step you take. Anyway... it's a long story, and I don't like to go into too much detail.
Hi eduardo,
In the long discussion in bulgarian site "metaldetecting.eu" (from 2023), the author of "Micron Hybrid Smart Pulse" said that this project from the beginning is for middle size objects - preferably coins. He mention that if this project will be modified for small nuggets, the results will be not better than other good detectors.
First, check that both demods are working correctly: IC5a should have a positive-negative target signal and IC5b should have a negative-positive target signal. If these look OK, then check the soldering of you GB pot, especially the pin to the ground channel.
Originally posted by Carl-NC View PostIf you are expecting a roll of solder to be a low conductor, it's not; it's a high conductor, just like the nail. Get some household aluminium foil and cut a 25cm square piece, use that for a low conductor.
In the previous videos you saw the behavior on coins.
It always behaves the same.
You didn't tell me your opinion about the voltage?
Is that how it should act?
I still have doubts about the quality and originality of these TL072s.
