searching for arm cup / arm rest
  • searching for arm cup / arm rest
    hello
    for a diy session i´m looking for some arm cups
    like the garretts shown there
    http://detector-distribution.co.uk/s...rchStr=arm+cup
    i´m not going to order there because theshipping cost increase as more as you buy
    so at the end the double the price for a simple pair of arm cups
    so i anyone has some spare parts laying around please help
    would buy up to ten oft hem ore more later but for fair price and shipping cost
    shipping will be to germany
    kind regards
    and many thanks for reading
    I've seen some very similar crutches with almost identical cups being used by elderly people. I bought mine second hand as "the granny doesn't need them any more"
    I didn't find a better picture than this one:
    http://www.seniorhealth365.com/wp-co...DIUM_IMAGE.jpg
      Something locally available (distributed in Croatia too, under different name), around 12-13E, very practical (this particular “safe in” model).
      http://www.ortopedija-novizivot.co.r...-in-stake.html
        I've seen those as well, but the model I'm thinking of is much closer to Bernte's request.
        Point is that those are often available second hand.
          thanks friends for your ideas
          but crutches is that what i have enough from here
          i have build some special nearly metal free stems for pi machines of them
          but for next project i need only bare professionel looking arm cups
          nothing what seems to be fixed something
          if nothing goeas the next week i´m going to laminating some arm cups from carbon stuff
          but that need much time and nerves
          kind regards
            Hi Bernte
            Will tell you a secret to make the perfect arm cup thats looks so professional people will think its a ML or such like.
            Been using these for the last 20-30years and no one has cottoned on to what they actually are made of.
            Go and buy a length of plastic waist pipe, the type that is so commonly used as a down pipe from roof guttering to the main drain or soak away.
            Cut the width you require and cut dead center and you automatically have two cups , Get a file and round the corners, sand sheen off surface , Coat of base paint, then two coats of any colour you desire.
            My latest is electric blue because I am always on the look out for spray paint flog offs in auto shops.
            To Summarize : its cheap as chips, Very available, (almost every house uses them) you can cut cups to any depth you fancy, so very adaptable to arm/elbow thickness, robust, Light as a feather, non conductive, And icing on the cake professional finish.
            So very simple to produce and very effective.
            If you want any pictures of any I made over the years just ask and will put some on here, they tail back from the 70s with my first project from Everyday electronics 1972 .
            Food for thought if you dont want to make them yourself then I will make them for you at £5.00 each +pp, any colour you chose as a one off, then after that its buy one get one free at the same price.
              If you have time Dave please post some thanks.
