Wanted whites dfx
  • Wanted whites dfx
    hi i would like to buy a whites dfx Sussex area if possible secondhand
    Are you still looking, If so let me know because I need to unload some of my detectors which includes the DFX
      hi dave, do you still have those igsl boards?, i know its a while since you mentioned them but i want to build one and i cant find an isgl board.
      its the version i fancy, if not i will build the tsgl edu.
      thanks
      aly.
        Hi Sinclair
        I got isgl both versions boards one of each new untouched minelab/tesoro versions.
        Also i have 2 off two tone conversion boards made myself for the tsgl project one of which is fully populated but never applied to project.
        In stock also concerning these projects is 2 off manufactures Tesoro coils both 8" brown which is original stock coil and the10" web coil fitted with the standard 5 pin plugs for use with these projects, Also 2 off completed ivonics TGSL with all the worth while modifications .
        Make me a sensible offer on the lot if you fancy, or if just the boards you can have at cost plus postage
