  • i noticed i did put 105 cap on place of 104 cap LOL. changed it.
    • Keith
      a parcel is on the way to you. http://ipic.su/img/img7/fs/CIMG6498.1554487747.jpg
      • that's fantastic kt. looking forwards to it's arrival.........
        • after arrival. solder mosfet and HV diode on board. clear pads by alhocol. check by magnifier 6x-10x the soldering points, they have not to be closed.
          test PCB on table with small coil 300-550mH and power supply 12V. all pots have to be set in marked position. then after success collect it in a housing.
          all the best.
          • https://youtu.be/4N2YLmLWSj4
            guys i repeat some things again.
            If you want to use Delta Pulse with just small coil (like the video).
            You can tune FIRST DELAY to its minimal 12-15us. Change C4 to 820-910pF. R7 to 7.5k.
            Change C5 to 1nF to decrease a STROBES' WIDTH to 20-25us.
            Tune frequency to 300pps. Change C1 to 10nF and R1 to 160-180k.
            • also Keith inportant knowledge. protect the board against electrostatic discharge. remember - on your body, hands,
              ALWAYS IS ELECTROSTATIC CHARGE. so if you want to take the pcb take for MINUS or PLUS power supply tracks.
              close all pots by one naked wire and connect this wire to especial point on board,
              take just for this wire at first.
              just read https://en.wikipedia.org/wiki/Electrostatic_discharge
              i do not want open new thread on the subject because my english is zeroed.
              follow this simple rule. CMOS chips is afraid the HV ESF discharge onto the way 'your hands <---> CMOS pins'.
              • Comment
                • Comment
                  • Comment
                    • Keith do not write that you did not receive the parcel.
                      i see ALL!
                      it is in YOUR HANDS NOW!
                      08.04.2019 18:19
                      Sent to delivery office
                      Did?ioji Britanija
                      09.04.2019 10:19
                      Delivered to recipient
                      Did?ioji Britanija Ne61 1aa
                      • Hi kt.
                        yes i received it my good friend. thanks very much. it came much quicker than i thought it would.......
                        • quicker than LOL!
                          • LOL....
                            • to220.... to92..... to... to.... to.... TOOOOOOOOOOO
                              Keith you have to know ABC or you'll kill me (((
                              • HIGH VOLTAGE diode STTH1210
                                http://pdf1.alldatasheet.com/datashe.../STTH1210.html
                                Ultrafast recovery - high voltage diode
                                Features and benefits
                                ■ Ultrafast, soft recovery
                                ■ Very low conduction and switching losses
                                ■ High frequency and/or high pulsed current
                                operation
                                ■ High reverse voltage capability
                                ■ High junction temperature
                                ■ Insulated packages:
                                TO-220Ins
                                Electrical insulation = 2500 VRMS
                                Capacitance = 7 pF
                                TO-220FPAC
                                Capacitance = 12 pF
                                Description
                                The high quality design of this diode has
                                produced a device with low leakage current,
                                regularly reproducible characteristics and intrinsic
                                ruggedness. These characteristics make it ideal
                                for heavy duty applications that demand long term
                                reliability.
                                Such demanding applications include industrial
                                power supplies, motor control, and similar
                                mission-critical systems that require rectification
                                and freewheeling. These diodes also fit into
                                auxiliary functions such as snubber, bootstrap,
                                and demagnetization applications.
                                The improved performance in low leakage
                                current, and therefore thermal runaway guard
                                band, is an immediate competitive advantage for
                                this device.
