SM Pro Surf PI Board complete
  • SM Pro Surf PI Board complete
    I'm looking to sell this board to fund a personal project I'm currently working on. Its an sm pro surf pi, complete. It was purchased from
    one of the vendors on ebay last may as a completed board. It will come with on/off switch wired, pots wired, 5.5x2.1mm DC jack wired and
    headphone jack wired. Ready to install in your case.
    Only thing you will need to do is wire your coil plug and make/add a coil.
    $85.00 shipped to lower 48 only, anywhere outside the US, Hawaii, Alaska or Canada contact me via pm
    to work out shipping.
    This board has not been modified, it is a straight up sm pro surf pi in good working condition, hasn't
    ever been taken out and used other than in the backyard testing and in the garage.
    Video proof it works
    Well I couldn't edit so am adding comment.
    I was questioned and told on another forum it looked blown up, well its not, I chipped the ceramic on the
    390 resistor but it doesn't effect anything. So I made a quick vid to show it works and is just fine.
    I personally wouldn't post something on a classified if it didn't work, just not that kind of guy...
      Reduced.....$75.00 TYD
        Any takers for $65.00
          This is an old thread but had to say it. Your damping resistor is toast. Did you not notice that in the very first pic?
            Actually is wasnt toast, it was just fine. it was just chipped and it is still a perfectly working unit... no longer available.
              I see this is no longer avaiable, but i sent you a couple pms with a question but you didnt answer, so i posted here and maybe you will get this notification
                He was sick a while ago not sure if he is still with us.
                  Thank you 6666 for the response, i kinda figured as much, same with a couple other members, like krinaz didnt respond also, too bad
