Portable oceangraphic winch
  • Portable oceangraphic winch
    New oceangraphic winch for sale, designed for use with side scan sonar and magnetometer,
    Probably the most powerful 12vdc portable oceangraphic winch on the market with 198kg pull suitable for heavy
    weighted tether and high drag.
    12v DC power max 180 amps. 1.1hp motor, 153:1 ratio.
    Min retrieve rate 7.6m/min, 198kg max pull
    chassis and drum are fully TIG welded 304 grade stainless.
    Weather covers are 2mm H22 marine grade alloy fully TIG welded.
    Size:
    220mm Drum (large bend radius)
    Endplates: 400mm
    drum width: 317mm
    Capacity: 300m based on 8mm cable
    zero-load retrieval rate of the 220mm drum is
    26m/min
    Slip ring:
    Mercotac 630
    6 conductors (2 conductors @4amps, 4 conductors @30amps)
    Controller:
    Water resistant handheld
    Price $12,578
    Insured delivery worldwide included
    Please see the picture at the top of the first post. If anyone has any inquires or questions please ask. Thanks very much.
      Reduced to 10,000 usd for quick sale. Bought but never used. Bargain of a lifetime. More powerful than the leading and more expensive winch of larger size, suits small boat! and heavy load e.g weighted magnetometer tethers when searching for small items etc. Thanks for looking
        still available
          Reduced to sell fast 4600 EUR
            LOL You can buy a nice boat for $10,000......
