If any of you wanted me to build PCB layout, just send me schematic make sure you have the good verify schematic, give me in 2 weeks, the PCB LAYOUT ready for you, price etc, just pm me. Thanks...
Schematic to PCB for any Metal Detector
I'm offering PCB Manufacturing, ONLY for metal detector purpose, you can send me layout in .pdf in minimum 10 piece, for lower count go to silverdog or KT315,,,,, if you want higher quality Needed File:
Gerber format RS274X
NC Drill: Excellon 4:2 (4 integer-2
Decimal)
ZeroSuppressio: Trailing Blank
Scale Factor: Metric
Layers:
Top Layer
Bottom Layer
Top Soldermask
Bottom Soldermask
Top Legend
Bottom Legend
need more if multilayer (up to 4 layer)
Minimum production 10pcs
Available PCB: CEM1, FR4, FR4-HF
Size in single layer:
min @ 80cm²
max @ 28cm x 38cm
Double Layer and Multilayer (max 4 layers)
min @ 80cm²
max @ 18cm x 28cm
Please PM for price etc, thanks Geotech!!
daihatsu - 11-15-2015 11:24 PM Edit Report
Welcome...
Moderation Tools(1)
Showing Visitor Messages 1 to 2 of 2
I'm not making myself. It's made by fabric, different fabric, for regular quality and higher-level quality. But price is also differ. It doesn't need .pdf actualy all Image are Welcome, but .pdf more fast in timing proces, it was for scaling need. If you happen made in .brd .pcbdoc etc please export it first to Image .bmp .png .jpg etc.
For higher quality I need only gerber as stated before.
So that is, thanks KT315
Originally posted by daihatsu View PostIf any of you wanted me to build PCB layout, just send me schematic make sure you have the good verify schematic, give me in 2 weeks, the PCB LAYOUT ready for you, price etc, just pm me. Thanks...
I can make it for just One Week / 7days
Originally posted by daihatsu View PostI'm offering PCB Manufacturing, ONLY for metal detector purpose, you can send me layout in .pdf in minimum 10 piece, for lower count go to silverdog or KT315,,,,, if you want higher quality Needed File:
Decimal)
Layers:
Top Layer
Bottom Layer
Top Soldermask
Bottom Soldermask
Top Legend
Bottom Legend
min @ 80cm²
max @ 28cm x 38cm
min @ 80cm²
max @ 18cm x 28cm
- Regular PCB lead time only 2 days (with or without silkscreen etc)
- High Quality need 5 days
- Minimun @10pcs
