Looking for manufacturer of the Bulgarian Metal Detector housings
    Originally posted by SVEN1 View Post
    SGS?
    http://www.geotech1.com/forums/member.php?8553-SGS
      Hi! For information from Bulgaria : No manufacturer of metal detectors in Bulgaria ( Micron, Golden Mask , Vista, Pirat , Miladin) DID NOT SELL PARTS FOR MODELS THAT PRODUCE !!
        Are you sure?
          Georgi, can you give Bulgarian forum links with sell-buy matter? i know one, but it seems slightly passive http://bg-draga.com/index.php
            this ukrainian guy does submersible case "for ace 150 250 350" http://www.md4u.ru/viewtopic.php?f=31&t=10052
            where can i get one
              translated and sent email .they look great
                just sent money to this guy hope its real
                  did welcome him to here.
                  ps. answered that he is here and later will open a thread.
                    I ordered one as well yesterday after contacting him. He has very good English.
                    Guaranteed waterproof to 6', submersible to 30'.
                    It might fit my PI PCB, if not will use it for an Ace.
                    Only thing is the connectors in the above pictures are not waterproof? I plan on changing connectors if it arrives that way.
                      interesting a way the ordinary connectors moded to submersible 0_o
                      something real new for me. translated his text via net.
                      Of what many dreamed - came true. Now loved by many Asya (russian alias for ACE) became an amphibian.
                      I offer to purchase underwater boxing for Garrett ACE 150*/250/350.
                      ACE 250 and 350 are completely compatible to boxing on management.
                      ACE 150 - management is limited.
                      Boxing material - polycarbonate (very strong, but also very soft in respect of scratches)
                      Boxing was made taking into account that search will be run in the mode - on foot.
                      That is not small depths - in actual practice ~ 1 meter of boxing (the searcher up to a breast, a neck who as will get used). For these reasons it is possible to use any earphones with the socket big Jack (mono).
                      Is established on a regular place of the control unit.
                      Special skills it isn't necessary for installation.
                      Testing was held at a depth of 3 meters (successfully, at this depth I lay within days)
                      We take average figure 2 meters, it and will be the guaranteed boxing immersion depth.
                      Boxing has positive buoyancy, when finding the purpose it is possible to release the detector and he will swim near the searcher.
                      Connection of the coil standard - it is a little necessary to finish the socket:
                      To disassemble the socket, to miss the mark with silicone adhesive contacts (goes in a set), and after drying to fill a socket cavity same with silicone adhesive and to collect.
                      Then, after full drying it is necessary to grind off a socket end face approximately on 1mm.
                      The sealing ring is inserted into the coil socket on boxing (in a set)
                      the end face of the socket of the coil is greased with silicone greasing (in a set),
                      the nut on the socket is inserted and is standardly tightened (not strongly)
                      The exit to earphones, also has a sealing ring which doesn't allow water to get into a nest.
                      I ask to pay attention that at the case of boxing there can be inclusions of vials of air, and on a surface there can be small scratches.
                      These factors don't influence durability and working capacity.
                      Complete set:
                      Underwater boxing for Garrett ACE 150*/250/350 with all sealants.
                      Second set of sealants.
                      Silicone adhesive.
                      Silicone greasing gel.
                      Packing box.
                      It is made in Ukraine.
                        crash test
                          moding of connectors
                            setting of housing on steam
