hellenic pulse
  • hellenic pulse
    https://www.hellenic-pulse.com
    Moved to Buy-Sell-Trade section.
        I surprised the guy following isn't picked up by the detector. Appears to be about a metre away in some of the videos. Having said that the videos don't show much. I could walk around a field with some waste pipe then add a beep every now and again it if would look the same
            There appear to be two different detectors on the website. One is a PI, and the other is a dowsing rod with some do-nothing electronics.
            Since the title was "hellenic pulse", I allowed the advert to remain, and just moved it to the correct location.
                i dont want to sell it,,,, i just ask if someone knows something about it
                  They sell something that almost certainly doesn't work
                  Doesn't give me much hope their other product will be both genuine and or affordable.
                  In one video a small coil PI had turned into a two man job ?
                  In another the guy following appears to get quite close to the edge of the coil but the battery and laptop he carrying aren't detect
                  I didn't watch them all I gave up at that point
                    In that case you should have stated that, and not just posted a link.
                      BR
                      this site is not indexed in google. you can give the links but all your attempts will being completely ignored.
                        SL lay file taken from RU zone
                          https://www.youtube.com/watch?v=Cpfdccj67vA
                          Is it me or does it beep before the target is lifted up at the 1:28 mark
