Best place to by enamelled wire 0.5mm ? for coils is this what I need ?
Pi detector..
The two diodes 1n4148 these values are so common near the coil, but others must of tried other diodes is there a better one or is this just as good as it will ever get ?
Practically they work as well as anything else. I've tried "ultrafast" diodes and Schottkys but they are no faster.
A key element in faster diode recovery is the amount of clamp current you start with. So a higher resistor value buys you a lot more speed than a different diode.
so I chatted with a UK guy off here.. Great bloke
he said...
"Until you’ve experimented with coils and built a few I wouldn’t spend too much money on coil wire. Initially all I used was the following stranded hookup wire from RS. RS PRO White, 0.13 mm? Hook Up Wire, 100m Stock no.:872-4473It’s only ?10.43 for a 100m roll and I’ve made quite a few coils "
its got an MPPE insulation much thinner than the normal PVC, so I now have it in red black and white.. from what I have read its a little more Green too..
Not made a coil yet... LOL
He's right. Start with ordinary insulated wire, you'll get good results for little money. Using e.g. Teflon gets very little extra for a lot more money.
