SonarTRX 12.1 - Faster & w/Beam Angle Correction
  • SonarTRX 12.1 - Faster & w/Beam Angle Correction
    Version 12.1 of SonarTRX sidescan processing software is now available.
    Some of the new features are...
    • Faster import and processing of sonar channels in parallel (on Multi-Core CPU's)
    • Sonar Beam Angle Correction (BAC) algorithm for bringing out more details in the slant range corrected images.
    • Altitude calculation & bottom digitizing feature is now part of the lower cost versions (SonarTRX-SI and SonarTRX-LSS).
    The release notes can be found here:
    http://www.sonartrx.com/web/Home/Support
    ...and a sample of how Beam Angle Correction can be used to lighten up the slant range corrected images at far ranges / large angles:
    http://www.sonartrx.com/blog/post/So...orrection.aspx
    Tore
    tore@sonartrx.com
    www.sonartrx.com
