Source code
    Thanks for the PIC info Carl, will order some.
    cheers
    6666
      Excellent job Ap!
        Originally posted by ApBerg View Post
        First impression:
        for such a small circuit the sensitivity is not bad.
        ... and it is?
        Pro work, Ap, congratulations.
          Just a quick note...
          The .lay file inside Ap's zip file can be viewed with the freely available sprint layout viewer, see: http://www.abacom-online.de/uk/html/sprint-layout.html at the bottom of the page.
          Joop
            For those who want to compile their own Hex code, I had a crack and it seems to work.
            Download MPLAB ver 8.76, it comes with the Hi Tech compiler.
            Install Mplab 8.76 and the compiler, when you install the compiler select the LITE mode.
            Make a new folder and place the .c file in it (PI2.c)
            Start Mplab, then select the project wizard,
            select device
            select the Hi tech tool suite (should be default)
            create a project in the same folder with the .c file (call the project any name)
            then select the .c file and click ADD file to project
            click finish
            then click the build ICON , this is a BLACK icon with red dot and bar in Mplab at top of page
            if it all works you should get a ********** Build successful! ********** message in the output window
            and the HEX file will be in your folder
            good luck
            6666
              select device
              click finish
              good luck
              6666
              That reminds me of the time when you could buy a cheap Microsoft Office upgrade CD, and during the installation you were asked to browse to the location of the Office software on your hard disk. Of course, if you didn't have Microsoft Office, you couldn't load the upgrade. However, if you browsed to the CD instead of the hard disk, the installation software thought you had an official version and quite happily loaded a full Office Suite onto your computer.
                OOOPS
                I must explain my comment in the first line "I had a crack and it seems to work"
                this does not mean I had a software CRACK,
                this expression is Australian slang for having a try at getting something to work.
                The expression is "have a crack at it " or " I had a crack at it" or "have a go at it" or "give it a crack mate" etc.
                I made the post so ivconic could try it, the mplab software works fine and the hitech compiler
                works fine in Lite mode,
                but if you operate in PRO mode you may get a more compressed hex code that may look different from what Carl published.
