Probe PCB from Silverdog
I'm not sure how the AGC part of this circuit works, but it appears to be accomplished via the 100k resistor between Q5 and the pulse input.
I am not sure that in this case TR mean "Transmit - Recieve" but maybe ThReshold or something else. Regarding Whites terms glossary TR "Usually describes non-ground rejecting detectors or modes.", but CM1000 is ground rejecting, so TR should mean something else.
Originally posted by WM6 View PostHi Qiaozhi, where did you find Q5 in those AGC - TR CM1000 schematic?
The only possible answer is that I made that post after midnight.
I should have referred to the CD4024, so maybe I was looking at pin 5.
Originally posted by WM6 View PostI am not sure that in this case TR mean "Transmit - Recieve" but maybe ThReshold or something else. Regarding Whites terms glossary TR "Usually describes non-ground rejecting detectors or modes.", but CM1000 is ground rejecting, so TR should mean something else.
