Has anyone built the PI5?
I made a go of it but didn't do so well but I always build on perf or punch board.. Does someone have a pcb drawn? not sure why they didn't add one in the book
like the first 4. For whatever reason I cannot seem to get it drawn right and I SUCK at trying to use any of the software to do it..
If anyone has built it, how well does it work and what coil specs did you use. I guessed at using a 350'ish uH coil and have to assume that would be fine
for what it is.
Did you use the 5532 or swap to the 5534?
Power consumption, what do you get on a set of batts (8 AA's)?
for what it is.
