Originally posted by 6666
(This doesn't really warrant a new thread but avoids poluting a Barracuda one.)
Mostly the build (about 12 months ago now) was as in the emailed final schema. (So quite different from version one book schema!) I reduced the pulse width to match a low resistance coil and I probably played with the audio to reduce the volume a bit for what seems to be a sensitive headset. So no real changes.
Current was I think adjusted down to 100ma with battery a little under 12V (3 cell LiPo as I had it to hand) . I think a blew a chip at some point, when using a full 12V (bench supply) and found that the chip was actually rated for about 6V. Maybe there are chip variants. I wouldn't have expected rating variations back then.
The coil is very low inductance (now I have a meter) 149uF, 0.7ohms, 300pF. Resistance is probably approximate. I don't trust accuracy of either of my meters at that low resistance.
It uses loosely tied, thick insulated, 12V multicore wire... Nothing fancy like screening. The figures look wrong I think. Capacitance should more like 100pF.. I do experience marginal ground effects, which are distinguishable from true object contacts. If shielding reduces sensitivity, I'm all for omiting it☺
Threshold was marginal at 9V and the unit felt like it ran better with the higher voltage.
Does your query mean you have had trouble with the build?
Ray
