Question about fig 12-10 first edition please.
Hi Q, I was wondering if you would remember what the DC voltage should be between the output of IC1A and resistor R9, the text dances around the value of the voltage and says words to the effect that it has to be a value to keep the fet in its proper operating region but never mentions what that voltage is .
I built the cct but only had a split 12 volt supply and I got around + 5.3 volts, so I guess with 9v is should be around + 3 to + 4 volts ? thanks.
