PHASE ANGLES??? Kind of complex, and the RAREITY of Gold Nuggets, based mainly on the sizes from what I read. Small gold nuggets are more numerous then LARGE GOLD NUGGETS you see, so a RARE NUGGETS was made into a chart. Going to stick it in here below too... Also took some material, on PHASE ANGLES too, so reading about them should be very interesting for us. Us is you and me..... I like learning new things all the time. What about you guys? Want to learn some more today??? Whoops, I managed to stick in Jack Giffords file, but lost the location of the Chart of rare gold nuggets. So lets just learn about Phase Shift and Target Identifications shall we??? There is a link to the file, it is right below.. The title is Phase Shift and Target Identification and it is a .Doc file...
Introduction to Phase Angle
Phase Shift and Target Identification.Doc
Phase angle refers to a particular point in the time of a cycle whose measurement takes place from some arbitrary zero and its expression is as an angle. Furthermore, a phase angle happens to be one of the most important characteristics of a periodic wave. A periodic wave is one whose displacement is characterized by a periodic variation with relation to distance or time or both.
The continuous repeating pattern of the periodic wave helps in the determination of its amplitude, period, and frequency. Furthermore, phase angle refers to the angular component periodic wave. Moreover, it is a complex quantity whose measurement takes place by angular units like degrees or radians.
MELBETA
Ok, found the Rarity Chart too.... It is right below and is large enough to keep and to read!
MELBETA
