UNBELIEVABLE #10 (BOUNTY HUNTER OUTLAW DE 280)
  • UNBELIEVABLE #10 (BOUNTY HUNTER OUTLAW DE 280)
    Currently on Ebay but watch out for that opening bid! $200.99 Ebay# 160097392764 I got mine for $160.00 less!!! Maybe this seller knows things that we do not know!!................HH..................Joe
    Bounty Hunter DE 280 Outlaw
    I like this detector, maybe it is because of the green light which glows faintly for deep objects and glows a very bright green for shallow objects! GREAT FOR NITE HUNTING! Of course, it is a VLF/TR design which does have some limitations! Since this thread was originally posted I have seen these sell for a lot less than $200.99...........................HAPPY HUNTING ...............JOE
      bounty hunter outlaw de-280
      i just picked up one of these de280's and have a question about it. maybe someone can help me about it. when i turn it on, it comes on right away, but the green light is bright and there is no adjustments. not sure why, maybe i am not working it right. also, does the ground balance knob just spin in circles? or is there a stop? also, can anyone find a manual for it for me? scans will be fine.
      thanks
      tim
        Not sure, my DE280 does not have a green light at all. My GB knob is a single-turn pot, though some models use a 10-turn pot which have slightly more drag when you reach the turn limits, but will keep on turning (no hard stops). Sorry, no manual.
          DE280
          Yeolde13, the light can be adjusted by using the tuning control. Adjust it to a faint threshold sound, while also holding in the retune/push button switch at the end of the handle and then release!! At this point the light will be a dim green. I never adjust the volume control to 100%. adjust to about the 75% mark! The threshold is the lowest sound that you can comfortably hear! Mine glows bright for strong signals and weak for deep signals! If yours is not doing this, then you may have set up the tuning blaring and in this set-up it will not differentiate between deep or shallow!...............Also you can look for deep versus shallow objects by also using the meter and the audio!...................................HH....... ...........Joe
            DE280
            Yeolde13, There is a possibility that you have the 2 battery packs connected wrong! One battery clip is for a 9 volt battery and the other clip is for a 12 volts battery pack. If this is connected wrong the detector will not work right! Thanks Joe
              thanks a lot
              hey thanks for all the help i wrote it all down so i cant forget it, but the new problem i encountered is when i turned it on this morning there was nothing at all i mean the light didnt come on or any sound, weard the battery check switch works showing the batterys are good not sure what happened. I had the larger battery pack on the "A" lead hope i had it right and this didnt cause the problem, any thoughts to what happened?
              also have a manual on the way to me they are available throw bounty hunter just email and they will send it out free to you, fron what i understand they have them for allmost all of there older metal detctors .....Tim
                How deep on a dime
                How deep can this detector pick up a dime.
                  ~6 inches.
                    old user
                    I obtained a manual from East Texas Metal Detectors, they seem to have a lot of manuals for old detectors, and Keith Wills sends them out.Only took me 30 years, a lot of useless manuals before I found them. They also do repairs on old detectors, and sell new ones.
                    Greg
                      Does anyone have the schematic for the Bounty Hunter DE280 Outlaw ?
                        .....You can try Keith Wills at www.brokendetector.com Joe
                          if anyone knows how are the battery cables (+) (-) about 9 volts and 12 v., I greatly appreciate.
                          Uploaded with ImageShack.us
                            I need help,,,, a technician changed some parts, which is the transistor 1 and 2 and with the arrow what is the diode? Thank you.
                              He's NOT a qualified technician if he's calling that 2.7 K resistor a diode !
