The 1220x and 1260x circuit are practically the same.
From ebay
Yep just the style of shaft different.
It's a 2cm behind the F1265x which I also own. But that's air testing and running at maximum. In the field you have to turn the F1265x down more unless you like digging coke and having loads of false signals.
Both will pull a pre decimal coin at 10" in my lawn. Deep target on the 1260 give a faint zip zip sound rather than the beep of the 1265
I would use the 1260x more except it does not have a no motion pinpoint mode. I use the pinpoint as an extra discrimination test. Iron gives a much longer beep
