Originally posted by Willy Bayot
View Post
AMX TX
Originally posted by Willy Bayot View Post
The droop rate does not depend too much on the quality of the simulation of MOSFET, it mostly depends on the amount of energy ABSORPTION of the ground and targets and its variations..
What we know for sure from real experimentations is that such a tiny droop measured at XMIT current level induces a HUGE signal offset at the end of the receive stages after a total gain of several hundreds. This dramatically reduces the range of measurement of the ADC before saturation.
This is the reason why we insist on defining a COMPENSATION mechanism.
In my experience even the lower spec 10 bit ADC of an Atmega328P proved excellent sensitivity (0.3g gold nugget at 5cm, spiral monocoil) with a preamp gain of 17 using the internal 1.1V reference voltage plus software oversampling/decimation (64 samples to add 3 bits) and low-pass filtering.
Originally posted by Teleno View PostSuch high gains are unnecessary and counterproductive when using an ADC of 16 bit and up. Unnecessary because the noise level of the signal is already higher than the resolution of the ADC. Counterproductive because amplification reduces the dynamic range, the bandwidth, adds noise, offset and delays.
That would mean that a ARDUINO NANO could do the job??
Thus, we have found the right platform for this project??
If the future experimentations in this project prove that you are right, all is well for me.
The main condition to success is first to keep the SNR high enough before data capture.
In the past, we have failed to get a high enough sensitivity using direct sampling with an internal 12-bit ADC (DMA-based at 0.7µsec per slot on a STM32) and software oversampling/decimation.
Maybe we have made some mistakes in our design or in our implementation!!!
It worked for me. You can see some code and the de-noising process in this thread https://www.geotech1.com/forums/foru...noise-question
The schematic in this thread https://www.geotech1.com/forums/foru...260#post313260
This is the exact same problem encountered in a square wave drive VLF detector. A square wave TX voltage produces a triangle wave TX field, and ground then induces a square wave voltage on the RX coil. In other words, big offsets. It's really the same problem you encounter in sinusoidal VLF designs where the X-channel ground signal limits the dynamic range. In those designs, you simply limit the X-channel gain. In the square wave design, I was once looking at methods to dynamically buck out the ground component. I should go dig up those notes again.
Note that this function is not required in the raditional PI technology since the whole energy accumulated in the coil is spent in th edamping resistor at each pulse period.
Originally posted by Tinkerer View PostIn the simulation we added a RX circuit.
You will notice that if you change the K L1 L2 0.3, and/or R19, R10,R3, The absorption of the RX coil changes and correspondingly, the slope of the TX current changes.
[ATTACH]n409297[/ATTACH]
Both sides of the RX coil are at virtual ground so that there is no reverse mutual coupling. RD can be anything you want and it doesn't affect the transmitter. During normal operation it appears RD has no effect, although it actually does because of the finite GBW of the amps. Since there are no flyback spikes on the opamp inputs, the diodes are only needed if the TX circuit starts running before the opamps are powered up.
The gain of the circuit is RG/RL so coils are a little more critical, and the RGs may need to be PTC resistors. A potential drawback with this circuit is that the output signal is no longer the derivative of the incident RX magnetic field. Instead, it is the same waveform. This means ground is now a square wave instead of exponential spikes. But his might actually be easier to deal with.
A problem with this circuit is that the RX damping and input resistors get reflected back to the TX coil because of mutual coupling. This happens whether you increase k or present ferrite ground. A circuit that avoids this is a current-mode RX amplifier, like this:
https://www.geotech1.com/forums/foru...212#post204212
I think this interesting part of the discussion should be moved to the AMX RX topic.
Originally posted by Carl View PostTrue, an error in the null shows up as a square wave output, same as a ground signal. It might not be difficult to compensate.
In an ideal shorted coil (zero resistance) the current is the integral of the EMF divided by L
This implies that the induced current has a "memory" and there's no need to sample early. The tau of the target becomes irrelevant by integration.
In a real shorted coil the memory decays at a rate L/RL, which is much slower than L/Rdamp so we can sample later without much loss of gain.
- This approach relaxes dramatically the timing constraints.
The disadvantages:
- The information on the target's tau is lost.
- Any error in the induction balance is also integrated and can saturate the preamp.
The approach is suitable for a monocoil too, as in the following schematic:
The depletion MOSFET transitions sharply from high resistance to low Rdson. By dimensioning R6 and Rdamp the switching instant can be made close to the zero crossing of the coil's current. Together with a constant energy drive scheme the set up should be stable. The Rdson of the depletion MOSFET should be as low as possible in order to short the coil to virtual ground. This is similar to Moodz's trick but not exactly.
[ATTACH]n409296[/ATTACH]
The TX current can decrease or increase depending on the TX voltage setting.
When the TX voltage setting is just right, the TX current is nearly flat.
The losses are resistive including RDS of the Mosfets, resistance of the coil and cable.
Now, if you approach the coil to a target, the target absorbs some energy from the TX coil field. This is especially noted with large targets and ground. Again, this changes the TX current slope.
Changes in TX current slope produce an offset in the RX as seen in the added RX preamp. In this RX preamp, no offset adjustments are made. [ATTACH]n409297[/ATTACH]- XMIT Coil dia 8”, 50 turns resistance 1 ohm, Inductance 850µH
- RCV Coil dia 4” resistance 2 ohm, Inductance 300µH
- MOSFET VDS : 800V RDSON : 360mOhm (not good)
- XMIT battery voltage : 2.45V
- Pulse period 200µsec = 5Kpps, two half-periods of 100µsec = 10K decays / sec
- Differential Receive chain : gain 50x to ADC input
- Coil Current : +1Amp to –1Amp = delta 2 Amp.
- 2 Amp x 50 turns = 100 Amp.turn
- Flyback Voltage : 900V
- Resonant Frequency : 160KHz, Flyback Width : 3µsec
- Battery Power Consumption : 4.7W
- Pulse Delay : 1.2µsec
- Signal Offset at ADC input : + 2.4V to –2.4V
- If more receive gain than 50x, Saturation
- XMIT Coil Current Ramp : 33mA over 100µsec
- RCV Voltage Ramp : 380mV
THUS,- Needs for Automatic Compensation of energy losses.
- This keeps the XMIT coil current CONSTANT
- Dramatically reduces the signal OFFSET at the ADC level
BUT- Signal Offset at ADC input : + 2.4V to –2.4V
The bipolar TX always has current flowing in it the notable thing being that the polarity swaps from period to period. (crossing zero point )
The other thing to note is that if you use some means of regenerative of active damping and then apply at TIA style ( zero input impedance AKA shorted coil ) style preamp to the RX function then we all ( should ) know that the time constant of the RX coil will be L/R.
If we have a really good system and our RX coil is 300 uH and 1 ohm then the time constant will be 300 microseconds !!
Ok if we dont have such a good RX system and the loop resistance of the RX 'shorted coil' is 10 ohms the time constant is still 30 microseconds.
I have done alot of work in unipolar systems where this principle is applied and it explains why with huge sample pulses spanning the whole RX period the detector can still resolve sub 0.1 gram nuggets. ... because the integration of the sample pulses and ref pulses is done across the time constant of the receive coils which are widened because they are 'shorted'. When you see the results there is a real AHA moment.
When the time constant is 'widened' by 'shorting' the coil there are no sudden target transitions occurring because they are smeared across the L/R response of the RX coil.
