AMX TX
  • #31
    Creating autonomous clocks is pretty easy with most modern micros. What's not as easy is to create autonomous clocks that vary dynamically, as might be required for a multiperiod waveform.
    But this is really a conversation for later. For now, let's focus on the TX driver itself. Clock drives can be figured out once we know what the clock drives need to be.
    • #32
      I wholeheartedly agree, but selection within the family is important. Not all of the PIC32's (very few actually) provide for CLC's, which I find very handy and satisfies the needs I previously could only satisfy with a FPGA or external discrete logic.
      Absolutely, one does need to first study and understand external hardware requirements, pulse timing, dead-time, etc. Then carefully read and study the data sheets to chose the best features to get the job done.
      Unfortunately, this may require buying and programming a demo board to learn what can and can not be done with a particular device.
      • #33
        Most standard micro-processors now provide pulse timing generation with hardware-controlled complementary output and programmable dead-time with a 10nsec precision.
        It is true for the STM32 family (Output Compare feature) which I personally experienced.
        It is also true for the PIC32MZ, PIC32MK and ESP32 families.
        No need for any interrupt features nlor FPGA capabilities. The timing schedule of each digital pin can be controlled from DMA and thus, completely in parallel processing with the rest of the application logic.
        As Carl noted, varying the parameters of the timings on-the-fly to support multi-period waveform is more advanced and not necessarily suppported by all processor families.
        I suggest that we first concentrate on an architecture which supports only a single period waveform at a time.
        • #34
          Actually you can measure the slope of the current if you need or want to... it is all in the way you configure the input to the sense amp (hardware selection) and how you configure the (cpu) ADC capture timing (software).
          Did you calculate what precision in time and value you can get from the measurements of the current on the two extremities of the ramp using an internal ADC (probably 10- or 12-bit) and your 100x gain amp?
          I still have some doubts that it is possible to get a good dynamic regulation in this way AT THE END OF THE RECEIVE CHAIN after all the amplification stages.
          If you have made real and successful experiments, I would be quite re-assured.
          • #35
            Originally posted by Willy Bayot View Post
            I still have some doubts that it is possible to get a good dynamic regulation in this way AT THE END OF THE RECEIVE CHAIN after all the amplification stages...
            I am not sure what you are saying... The current sensing amp (singular) is exclusively and continuously sensing/amplifying the input which is across the 0.033 ohm current sense resistor. In other words ("AT THE END OF THE RECEIVE CHAIN") what receive chain? In this case (INA293B3-Q1) is extremely accurate... that is what it is designed to do. Depending on the current range you need to be able to measure, you might need the C2(50x) or even the C1(20x) version. The timing accuracy and granularity of the ADC is wholly dependent on your microprocessor capability and your code.
            • #36
              Slight variations of the ramp generate large variations of signal offset at the end of the receiver stages. The regulation of the XMIT current should be precise enough to prevent the variations of signal offset in spite of the quick variations of energy absorption from the ground and targets. Moreover, the signal offset levels should be kept low by the regulation in order to apply a maximum amplification gain without saturation.
              We have used the method that you described using about the same circuits as yours but we were unable to make the necessary corrections of energy losses with enough precision.
              The only method which worked was to capture the variations of offset levels at the end of the receiver stages and apply the corrrections of XMIT current based on those measurements.
              • #37
                ... The only method which worked was to capture the variations of offset levels at the end of the receiver stages and apply the corrrections of XMIT current based on those measurements.
                Then you have solved your issue! If you want to discuss further, then we probably should start another thread.
                • #38
                  The issue was not fully solved. I just wanted to exchange ideas about the whole compensation subject since you have already explored it before..
                  Let's drop it for a moment, it will naturally come back on the table later in this project if we choose to use the CC approach.
                  • #39
                    Can someone tell me what a reasonable droop rate is for this TX method? Say, for a 1-amp peak current. I've run some sims (and I never ever trust the MOSFET models) and I see 10uA/us droop, which I don't believe is real. That is, for a 1-amp pulse 100us wide it droops ~1mA. But I have not actually built one of these so I don't know how it really behaves. I'm just trying to get a handle on how big of a deal an induced offset will be.
                    • #40
                      I've got to run some tests in next couple days to evaluate my new cable for my SuperD and I will make some observations for you. However any current, with my MOSFETs (800 V) and TX coil (315uH, 0.6 ohm), greater than ~550 mA causes the flyback to break the MOSFET diode reverse voltage rating, resulting in a huge droop. With flyback below the diode breakdown rating, I have minimal droop, but I will try to quantify that for you. Unless you use some super HV rated MOSFETs (or other technology) the CC current goal must be limited with Paul's design. For all other operational modes other than CC, this limitation does not exist.
                      • #41
                        I have no problem using SiC FETs @ 1200-1500V. Whatever it takes. Also, if the flyback is too high for the current you want to run, can't you just increase the parallel capacitance on the coil? Seems like this controls the transition slew rates and if you slow them down the flybacks decrease.
                        • #42
                          I don't either... that might get you to around 1A.
                          I had about 1.5nF inadvertently added (early in the development) and it reduced the flyback voltage to ~620V which allowed me to get to ~0.75 A if I remember, it also extended the transition from 1 us to about 1.8 usec.
                          • #43
                            The transition time (flyback width) directly depends on the RESONANT frequency of the circuit made of the COIL, its internal capacitance and the small capacitor connected in parallel.
                            For equal XMIT power voltage, the flyback increases when increasing the resonant frequency.
                            Increasing the XMITpower voltage while keeping the same resonant circuit, increase the coil current (and consumption) but also increases the flyback voltage.
                            We usually set the resonant frequency between 200KHz to 300KHz (period 5 to 7 µsec). This is a half-sine width (flyback) of 2.5 to 3.5µsec.
                            We adjust the external capacitor value to get this frequency with the given coil and adjust the XMIT voltage to stay just below the diode breakdown rating of the main MOSFET's.
                            • #44
                              The droop rate does not depend too much on the quality of the simulation of MOSFET, it mostly depends on the amount of energy ABSORPTION of the ground and targets and its variations..
                              What we know for sure from real experimentations is that such a tiny droop measured at XMIT current level induces a HUGE signal offset at the end of the receive stages after a total gain of several hundreds. This dramatically reduces the range of measurement of the ADC before saturation.
                              This is the reason why we insist on defining a COMPENSATION mechanism.
                              More than keeping the XMIT coil current CONSTANT, the compensation system is necessary to keep low and constant the signal offset at the ADC level.
                              • #45
                                AMX_SIMULATION_25turn_TX_coil.zip
                                The TX current can decrease or increase depending on the TX voltage setting.
                                When the TX voltage setting is just right, the TX current is nearly flat.
                                The losses are resistive including RDS of the Mosfets, resistance of the coil and cable.
                                In the simulation we added a RX circuit.
                                You will notice that if you change the K L1 L2 0.3, and/or R19, R10,R3, The absorption of the RX coil changes and correspondingly, the slope of the TX current changes.
                                Now, if you approach the coil to a target, the target absorbs some energy from the TX coil field. This is especially noted with large targets and ground. Again, this changes the TX current slope.
                                Changes in TX current slope produce an offset in the RX as seen in the added RX preamp. In this RX preamp, no offset adjustments are made. AMX_SIMULATION_50turn_TX_coil.zip
