Thanks Martin,
Loads of good info to get going with.
Much appreciated
Much appreciated
[I] delayVal = analogRead(delayPin); // Read the delay pot[/I] [I] mainDelay = defMainDelay + delayVal * clockCycle; // Offset main sample delay[/I]
[I]mainDelay = defMainDelay + (delayVal >> 1) * clockCycle; // Offset main sample delay[/I]
[I]mainDelay = defMainDelay + (delayVal >> 2) * clockCycle; // Offset main sample delay[/I]
[I] word potRead = 0; ... ... potRead = analogRead(delayPin); // Read the delay pot [/I] [I]if ([/I][I]potRead [/I][I]> (delayVal + 16)) delayVal = [/I][I]potRead [/I][I]- 16; else if [/I][I]([/I][I]potRead [/I][I]< (delayVal - 16)) delayVal = [/I][I]potRead [/I][I]+ 16;[/I] [I] mainDelay = defMainDelay + delayVal * clockCycle; // Offset main sample delay[/I]
// Arduino Pulse Induction Metal Detector // Pin assignments byte txPin = 8; // Assign pin 8 to TX output byte mainSamplePin = 9; // Assign pin 9 to main sample pulse byte efeSamplePin = 10; // Assign pin 10 to EFE sample pulse byte audioPin = 11; // Assign pin 11 to audio chopper byte boostPin = 12; // Assign pin 12 to boost switch byte delayPin = A0; // Assign delay pot to A0 // Program constants const float normalPower = 50E-6; // Normal TX-on time (50us) const float boostPower = 100E-6; // Boost TX-on time (100us) const float clockCycle = 62.5E-9; // Time for one clock cycle (1/16MHz) const unsigned long maxCount = 65535; // Value of 2^16 - 1 const byte readDelayLimit = 100; // Wait 100 TX periods (100ms) before reading delay pot const byte mosfetOn = HIGH; // Mosfet turns on when transmitter input high const byte mosfetOff = LOW; // Mosfet turns off when transmitter input low const byte syncDemodOn = LOW; // Sample gate turns on when input high const byte syncDemodOff = HIGH; // Sample gate turns off when input low // Detector timings float txOn = normalPower; // TX-on time using normal power mode float defMainDelay = 10E-6; // Default main sample delay (10us) float mainDelay = defMainDelay; // Main sample pulse delay float mainSample = 50E-6; // Main sample pulse width (50us) float efeDelay = 240E-6; // EFE sample pulse delay (240us) float efeSample = mainSample; // EFE sample pulse width (same as main sample) float txPeriod = 1E-3; // TX period (1ms) // Timing offsets float txOnOffset = 3E-6; // TX-on pulse offset (3us) float mainDelayOffset = 4.2E-6; // Main delay pulse offset (4.2us) float mainSampleOffset = 3E-6; // Main sample pulse offset (3us) float efeDelayOffset = 12E-6; // EFE delay pulse offset (12us) float efeSampleOffset = 4E-6; // EFE sample pulse offset (4us) float txPeriodOffset = 30E-6; // TX period offset (30us) // Program variables float temp1, temp2, temp3, temp4, temp5, temp6; // Intermediate calculation variables word txOnCount; // TX pulse word mainDelayCount; // Main sample delay word mainSampleCount; // Main sample pulse word efeDelayCount; // EFE sample delay word efeSampleCount; // EFE sample pulse word txPeriodCount; // TX period word potValue; // Voltage at the delay pot word delayVal = 0; // Delay pot value boolean readDelayPot = false; // Delay pot read (true or false) byte intState = 0; // Interrupt state machine byte readDelayCounter = 0; // Read delay pot counter void setup() { pinMode(txPin, OUTPUT); // Set TX pin to output mode pinMode(mainSamplePin, OUTPUT); // Set main sample pin to output mode pinMode(efeSamplePin, OUTPUT); // Set EFE sample pin to output mode pinMode(boostPin, INPUT_PULLUP); // Set Boost switch pin to input mode with pullup resistor calcTimerValues(); // Calculate all timer values noInterrupts(); // Disable interrupts TCCR1A = 0; // Initialize Timer1 registers TCCR1B = 0; TIMSK0 = 0; // Clear Timer0 mask register to eliminate jitter TCNT1 = txOnCount; // Load Timer1 with TX-on count TCCR1B |= (1 << CS10); // No prescaling for Timer1 TIMSK1 |= (1 << TOIE1); // Enable Timer1 overflow interrupt interrupts(); // Enable interrupts analogWrite(audioPin, 127); // Set audioPin with 50% duty cycle PWM } void calcTimerValues() { if (digitalRead(boostPin) == HIGH) { // Get boost switch position txOn = normalPower; // Set TX-on to 50us if HIGH } else { txOn = boostPower; // Set TX-on to 100us if LOW } temp1 = (txOn - txOnOffset) / clockCycle; txOnCount = maxCount - int(temp1); // TX-on count for Timer1 temp2 = (mainDelay - mainDelayOffset) / clockCycle; mainDelayCount = maxCount - int(temp2); // Main sample delay count for Timer1 temp3 = (mainSample - mainSampleOffset) / clockCycle; mainSampleCount = maxCount - int(temp3); // Main sample pulse count for Timer1 temp4 = (efeDelay - efeDelayOffset) / clockCycle; temp4 -= temp3 + temp2; efeDelayCount = maxCount - int(temp4); // EFE sample delay count for Timer1 temp5 = (efeSample - efeSampleOffset) / clockCycle; efeSampleCount = maxCount - int(temp5); // EFE sample pulse count for Timer 1 temp6 = (txPeriod - txPeriodOffset) / clockCycle; temp6 -= temp1 + temp2 + temp3 + temp4 + temp5; txPeriodCount = maxCount - int(temp6); // TX period count for Timer1 } ISR(TIMER1_OVF_vect) { switch (intState) { case 0: TCNT1 = txOnCount; // Load Timer1 with TX-ON count digitalWrite(txPin, mosfetOn); // Turn on Mosfet intState = 1; break; case 1: TCNT1 = mainDelayCount; // Load Timer1 with main sample delay count digitalWrite(txPin, mosfetOff); // Turn off Mosfet intState = 2; break; case 2: TCNT1 = mainSampleCount; // Load Timer1 with main sample pulse count digitalWrite(mainSamplePin, syncDemodOn); // Turn on main sample gate intState = 3; break; case 3: TCNT1 = efeDelayCount; // Load Timer1 with EFE sample delay count digitalWrite(mainSamplePin, syncDemodOff); // Turn off main sample gate if (readDelayPot == false) { // Check if read delay pot flag is false readDelayCounter++; // Increment read delay counter if (readDelayCounter >= readDelayLimit) { // Check if read delay counter has reached limit readDelayPot = true; // Enable read of delay pot readDelayCounter = 0; // Clear read delay counter } } intState = 4; break; case 4: TCNT1 = efeSampleCount; // Load Timer1 with EFE sample pulse count digitalWrite(efeSamplePin, syncDemodOn); // Turn on EFE sample gate intState = 5; break; case 5: TCNT1 = txPeriodCount; // Load Timer1 with TX period count digitalWrite(efeSamplePin, syncDemodOff); // Turn off EFE sample gate intState = 0; break; default: intState = 0; break; } } void loop() { if (readDelayPot == true) { potRead = analogRead(delayPin); // Read the delay pot if (potRead > (delayVal + 16)) delayVal = potRead - 16; else if (potRead < (delayVal - 16)) delayVal = potRead + 16; mainDelay = defMainDelay + delayVal * clockCycle; // Offset main sample delay calcTimerValues(); // Calculate new timer values readDelayPot = false; // Set read delay pot flag to false } }
// Arduino Pulse Induction Metal Detector // Pin assignments byte txPin = 8; // Assign pin 8 to TX output byte mainSamplePin = 9; // Assign pin 9 to main sample pulse byte efeSamplePin = 10; // Assign pin 10 to EFE sample pulse byte audioPin = 11; // Assign pin 11 to audio chopper byte boostPin = 12; // Assign pin 12 to boost switch byte delayPin = A0; // Assign delay pot to A0 // Program constants const float normalPower = 50E-6; // Normal TX-on time (50us) const float boostPower = 100E-6; // Boost TX-on time (100us) const float clockCycle = 62.5E-9; // Time for one clock cycle (1/16MHz) const unsigned long maxCount = 65535; // Value of 2^16 - 1 const byte readDelayLimit = 100; // Wait 100 TX periods (100ms) before reading delay pot const byte mosfetOn = HIGH; // Mosfet turns on when transmitter input high const byte mosfetOff = LOW; // Mosfet turns off when transmitter input low const byte syncDemodOn = LOW; // Sample gate turns on when input high const byte syncDemodOff = HIGH; // Sample gate turns off when input low // Detector timings float txOn = normalPower; // TX-on time using normal power mode float defMainDelay = 10E-6; // Default main sample delay (10us) float mainDelay = defMainDelay; // Main sample pulse delay float mainSample = 50E-6; // Main sample pulse width (50us) float efeDelay = 240E-6; // EFE sample pulse delay (240us) float efeSample = mainSample; // EFE sample pulse width (same as main sample) float txPeriod = 1E-3; // TX period (1ms) // Timing offsets float txOnOffset = 3E-6; // TX-on pulse offset (3us) float mainDelayOffset = 4.2E-6; // Main delay pulse offset (4.2us) float mainSampleOffset = 3E-6; // Main sample pulse offset (3us) float efeDelayOffset = 12E-6; // EFE delay pulse offset (12us) float efeSampleOffset = 4E-6; // EFE sample pulse offset (4us) float txPeriodOffset = 30E-6; // TX period offset (30us) // Program variables float temp1, temp2, temp3, temp4, temp5, temp6; // Intermediate calculation variables word txOnCount; // TX pulse word mainDelayCount; // Main sample delay word mainSampleCount; // Main sample pulse word efeDelayCount; // EFE sample delay word efeSampleCount; // EFE sample pulse word txPeriodCount; // TX period word potRead; // Voltage at the delay pot word delayVal = 0; // Delay pot value boolean readDelayPot = false; // Delay pot read (true or false) byte intState = 0; // Interrupt state machine byte readDelayCounter = 0; // Read delay pot counter void setup() { pinMode(txPin, OUTPUT); // Set TX pin to output mode pinMode(mainSamplePin, OUTPUT); // Set main sample pin to output mode pinMode(efeSamplePin, OUTPUT); // Set EFE sample pin to output mode pinMode(boostPin, INPUT_PULLUP); // Set Boost switch pin to input mode with pullup resistor calcTimerValues(); // Calculate all timer values noInterrupts(); // Disable interrupts TCCR1A = 0; // Initialize Timer1 registers TCCR1B = 0; TIMSK0 = 0; // Clear Timer0 mask register to eliminate jitter TCNT1 = txOnCount; // Load Timer1 with TX-on count TCCR1B |= (1 << CS10); // No prescaling for Timer1 TIMSK1 |= (1 << TOIE1); // Enable Timer1 overflow interrupt interrupts(); // Enable interrupts analogWrite(audioPin, 127); // Set audioPin with 50% duty cycle PWM } void calcTimerValues() { if (digitalRead(boostPin) == HIGH) { // Get boost switch position txOn = normalPower; // Set TX-on to 50us if HIGH } else { txOn = boostPower; // Set TX-on to 100us if LOW } temp1 = (txOn - txOnOffset) / clockCycle; txOnCount = maxCount - int(temp1); // TX-on count for Timer1 temp2 = (mainDelay - mainDelayOffset) / clockCycle; mainDelayCount = maxCount - int(temp2); // Main sample delay count for Timer1 temp3 = (mainSample - mainSampleOffset) / clockCycle; mainSampleCount = maxCount - int(temp3); // Main sample pulse count for Timer1 temp4 = (efeDelay - efeDelayOffset) / clockCycle; temp4 -= temp3 + temp2; efeDelayCount = maxCount - int(temp4); // EFE sample delay count for Timer1 temp5 = (efeSample - efeSampleOffset) / clockCycle; efeSampleCount = maxCount - int(temp5); // EFE sample pulse count for Timer 1 temp6 = (txPeriod - txPeriodOffset) / clockCycle; temp6 -= temp1 + temp2 + temp3 + temp4 + temp5; txPeriodCount = maxCount - int(temp6); // TX period count for Timer1 } ISR(TIMER1_OVF_vect) { switch (intState) { case 0: TCNT1 = txOnCount; // Load Timer1 with TX-ON count digitalWrite(txPin, mosfetOn); // Turn on Mosfet intState = 1; break; case 1: TCNT1 = mainDelayCount; // Load Timer1 with main sample delay count digitalWrite(txPin, mosfetOff); // Turn off Mosfet intState = 2; break; case 2: TCNT1 = mainSampleCount; // Load Timer1 with main sample pulse count digitalWrite(mainSamplePin, syncDemodOn); // Turn on main sample gate intState = 3; break; case 3: TCNT1 = efeDelayCount; // Load Timer1 with EFE sample delay count digitalWrite(mainSamplePin, syncDemodOff); // Turn off main sample gate if (readDelayPot == false) { // Check if read delay pot flag is false readDelayCounter++; // Increment read delay counter if (readDelayCounter >= readDelayLimit) { // Check if read delay counter has reached limit readDelayPot = true; // Enable read of delay pot readDelayCounter = 0; // Clear read delay counter } } intState = 4; break; case 4: TCNT1 = efeSampleCount; // Load Timer1 with EFE sample pulse count digitalWrite(efeSamplePin, syncDemodOn); // Turn on EFE sample gate intState = 5; break; case 5: TCNT1 = txPeriodCount; // Load Timer1 with TX period count digitalWrite(efeSamplePin, syncDemodOff); // Turn off EFE sample gate intState = 0; break; default: intState = 0; break; } } void loop() { if (readDelayPot == true) { potRead = analogRead(delayPin); // Read the delay pot /* update delayVal with hysteresis to avoid ADC and pot jitter */ if (potRead > (delayVal + 16)) delayVal = potRead - 16; else if (potRead < (delayVal - 16)) delayVal = potRead + 16; mainDelay = defMainDelay + delayVal * clockCycle; // Offset main sample delay calcTimerValues(); // Calculate new timer values readDelayPot = false; // Set read delay pot flag to false } }
