Baracude PCB files
  • #31
    You have affected the whole of China.
    • #32
      thanks =)
      still two pics of Bara accidentally found in global net
      http://www.metaldetectingworld.com/b...ting_p10.shtml
      Metal Detectors Required for Beach Hunting on Wet Sand & in Shallow Surf
      • #33
        preliminary part list
        • #34
          tantalums polarity
          • #35
            ok thanks for info
            • #36
              BOM file.
              bom.pdf
              • #37
                thanks for update, but remember with original tip127 and 2200uF instead of 6800uF i got something like disc mode
                • #38
                  Hi bernte_one! What disc mode you are reffering to? Is that the audio difference?
                  • #39
                    With some iron if you sweep slowly you get a double beep or warble. When sweeping at normal speed it has a dirty crack type tone compared to the nice clean normal tone
                    Not sure the change in capacitor is needed original and mine worked fine with 6800uF. Seems to be a combination of coil and settings. Mine was discriminating pretty well until I changed the 2N2222 and coil now no longer works.
                    • #40
                      black and white pics of board (for Naruto mainly)
                      Downloads.rar
                      • #41
                        NARUTO WRITE HERE. PLEASE DO NOT OVERLOAD MY MESSAGE BOX BY YOUR BARE REQUESTS.
                        • #42
                          • #43
                            tantalums placement
                            tantalums on botton side
                            • #44
                              Good evening Ahmed from Alexandria Egypt Please Is there an alternative to intensive 6n8j250
                              • #45
                                Originally posted by daihatsu View Post
                                Yup that's a good idea,,,I rather make my own pcb for that converter though
                                My thoughts exactly
