BARACUDA PI ABSOLUTELY NON-MOTION AND MOTION MACHINE
  • BARACUDA PI ABSOLUTELY NON-MOTION AND MOTION MACHINE
    Many of my friends say that baracuda is NOT A NON-MOTION md.. but i totally object it because i build it following the schematic and the result is it is a motion and non motion md..you just need to put on all the parts..
    Baracuda pi non-motion mode: http://youtu.be/xzTh-Vjns4o
      Good video. Have you made it switchable between Non-motion and Motion mode ? How is sensitivity between the two modes ? Could you make another video showing this ?
        Yes it is switchable.. a non motion mode is much sensitive than motion mode.. when i finish to put it back to the case i will make video.
          80cm sensitivity to big object
          Im using 16inches diameter coil enameled copper wire and i found it not good in sensitivity..this pi also operating with 9volts battery. Can someone tell me what kind of wire is the best for coil?
          Non-motion is sensitive than motion mode.
          Baracuda pi: http://youtu.be/0g2JgXntLm0
            Non-motion is sensitive than motion mode, on the table when tested but the real field is not...
              any of us who built and played with the barracuda will freely admit that it has the potential to be both non-motion and motion, the problem is you cant have both together, its either stable as motion appy's variant, or stable as non-motion original variant.
              getting both modes to work well in the same detector out in the field, thats when it fails.
