Baracuda Schematic
  • #31
    if you are still working on baracuda be clever and add a possibility to change pulse width and frequency
    i suppose i could be also work a bit better with two big caps in parallel on the coil drive stage
    • #32
      as I did not make Cuda before I am not in course which R/C are useful for change pulse width and frequency.
      also, with 100V C-E TIP127 is probably impossible to increase pulse width without waste of power on a heat, in my opinion.
      I would like to make a board as close to original one as possibly to get. also size of board grows with every additional pot setting at it. so original concept - submersible - with minimal amount of pots and swithes housing is more convenient IMO.
      • #33
        Привет всем - hello !
        • #34
          oh oh oh. узнаю брата Колю (c) had a lover of datasheets read something another besides the datasheets in his long life - ??
          • #35
            Welcome here enjoykin4 and thanks for interesting links to old electrical magazines in your first thread here (now blocked ?).
            There are in The Electrical Experimeter issue May 1917 nice small article about one of first (if not first at all) electronic (not electrical as before) approach to coin detecting. Thanks for Barracuda tips too.
            • #36
              Гы гы !! Не то чтобы совсем не попал,— сказал Винни Пух Пятачку,— просто не попал в шарик!! Ловиzhabrail_Harunovich_Baziev_Osnovyi_edinoy_teorii_f izikihttps://yadi.sk/i/YXD4J-1UgyckAElektrichestvo zemli.rarhttps://yadi.sk/d/jEjzsjXqgyckLУспехов в сборке !!С ув.Enjoykin4Thank you WM6 !! I am glad to see you here to.
              • #37
                good last schema. enjoy! Click image for larger version
                • #38
                  thanks for updating schema and pcb layout, very good quality
                  good detailed info
                  • #39
                    Great!!
