I am using 3x18650 batts = 11.5-11.8v at full charge, 11"/22w/26g enameled wire coil When I fired it up first time no sound and 7660 getting hot fast.
I discovered the 5534 was reversed on socket so fixed that. Now I get a beep when switched to ON after 10-15 seconds it just go's beep beep beep beep not very loud and no signal from coil at all. I have a 2n2222a transister I believe is on correctly but with all the talk of reversed pins Im not sure now. Adjusting the pots makes no difference. I've been reading through all posts but can't seem to make sense of pin outs and voltages for fault finding the (mosfet?) is a irf9640. If anyone can assist with idea's on what I mixed up that would be great.
