Baracuda Voltage Readings
  • Baracuda Voltage Readings
    Hi
    My name is Paul and this is my first post
    I recently bought the Baracuda Legend, Alex / Ap Rev2 kit, from Silverdog
    Unfortunately at the moment it has very poor detection
    A pair of pliers at about 4 inches
    A Twenty cent piece at about 2 inches
    Does not detect a Ten cent piece
    Does not detect Gold
    Below are the voltage readings
    If some could post the voltage of a working Baracuda,
    It would help me find what’s wrong with my Baracuda
    Your help will be greatly appreciated
    TC 7660 S
    Pin 1 7.75 Pin 5 -12.4
    Pin 2 6.4 Pin 6 7.7
    Pin 3 0 Pin 7 7.3
    Pin 4 -6.2 Pin 8 12.7
    LF 412 CN
    Pin 1 4.4 Pin 5 0
    Pin 2 -0.03 Pin 6 0
    Pin 3 -0.3 Pin 7 1.8
    Pin 4 -4.9 Pin 8 5
    NE 5534 AP
    Pin 1 2.9 Pin 5 -0.23
    Pin 2 0 Pin 6 0
    Pin 3 -0.3 Pin 7 5
    Pin 4 -0.6 Pin 8 2.76
    HEF 40106 BP
    Pin 1 0.6 Pin 8 -4.7
    Pin 2 -4.8 Pin 9 -0.23
    Pin 3 0.6 Pin 10 -0.23
    Pin 4 -4.8 Pin 11 -3.26
    Pin 5 0.18 Pin 12 -4.86
    Pin 6 -4.46 Pin 13 -0.05
    Pin 7 -4.9 Pin 14 0
    79L05
    Out -4.93
    78L05
    Out 5.00
    My name is Michel (I'm french) and it's my first post too. I've just assembled my Baracuda yesterday evening and I am just on testings.
    I dont know how you have mesured these voltages, but I expect that it's with a simple multimeter.
    Then, you can verify supply voltages (7805 and 7905 ie are good) and VCC / VDD of the CIs.
    The most of other voltages are not continuous (and some various frequencies) and I dont think you can read with a multimeter, but with a scope.
    Regards.
      a time to redesign of Bara board?
        Does IRF9640 or TIP127 get hot quickly
        If you reduce the volts to just bellow 8 volts does the distance increases.
          It does not get hot quickly. My bara works without heatsink. It just get warmer but not hot. Incorrect damping resistor value is one of the cause of getting it hot. Lowering the voltage will just make the bara unstable.
            Michel
            I don’t have an oscilloscope, just a multimeter.
            Thanks for the info, hope yours goes well,
            Koala
            IRF9640 slightly gets warm
            Does not run below 8 volts, just goes beep, beep, beep
            I carefully cleaned the back of pcb with Isopropyl Alcohol
            Now it detects a Ten cents at 2 inches
            Twenty cents at 6 inches
            Dollar coin at 7 inches
            Haven’t tested on gold yet, but at least I’m heading in the right direction
            Now its time to experiment with coils
              For best coil i suggest a spiral coil ir a spider web coil.
                "IRF9640 slightly gets warm
                Does not run below 8 volts, just goes beep, beep, beep"
                Sound like the 2n2222 is correct. There are a lot of versions some with completely different pin outs. Normally the cause of bad detection depth.
                Sound like it will just be a matter of dialling everything in.
                Gold ring seems to best for setting up delay and offset. Did you set offset to 0 volts. This is not always the best. Trial and error for best distance.
                  Just seeing if the 2n2222 is the correct way found. 180 digress out and the FET will instantly get hot unless the volts are below 8 volts.
                    The 2n2222 is the correct way round,
                    Already tested, when I put it in 180 degrees, the IRF9640 got hot very quickly
                    Put it back in the right way round and the IRF9640 only gets warm
                    I made a spider web coil and now it detects a gold ring at about 5 inches
                    Going to experiment with other coils over the next few days and will update then
                    Thanks for all your help
