Barracuda Legend Kit Problems
    iron was too hot
    soldering station
    thanks for the tip but its too late now i will upgrade at some point but until then i have no soldering iron, i has smashed it to little bits
    • Originally posted by Impulse View Post
      Well that is a shame.
      Electronics, especially when we do it remotely like we have been doing, is hard. It is a tough balance to understand what is known and seen on the other end of the conversation without actually being there. I did this frequently over a 31 year period but there the equipment was some that I was very familiar with.
      Take heart that you have not damaged your board.
      Do you still want to carry on?
      • KT315, have you ever looked at the barracuda gate drive pulses with a scope? If so, what amplitude should we expect? If you have been following this thread you'll see we have some unusual signals.
        • The board is still in one piece i have removed my soldering iron and i will get another (much better one). Old cart thank you for your patience i really want this to work as we have spent a good amount of time on this i thought all was lost, i dont want to waste all the time that you have put in to help me.
          OK the battery voltage is 11.5V
          Pin2 CH1 Pin4 CH2 here Click image for larger version
Name:	ch1 pin2 ch2 pin4.jpg
          • Impulse, here is what the sampling pulse (bottom trace) and the 5534 pin 6 signal should look like if it is correct.
            http://www.geotech1.com/forums/attac...9&d=1309516746
            Your preamp pin 6 signal is right, the sampling signal is not. In fact all of the signals associated with the 40106 look wrong. Once we get the 40106 working it should be a simple matter to adjust the delay to the correct position.
            Cheers,
            • o and the probes are 10X and the channels have been changed to 10X
                The board is still in one piece i have removed my soldering iron and i will get another (much better one). Old cart thank you for your patience i really want this to work as we have spent a good amount of time on this i thought all was lost, i don't want to waste all the time that you have put in to help me.
                Pin2 CH1 Pin4 CH2 here [ATTACH]35381[/ATTACH]
                Well, those are still wrong (perfect measurement, just wrong waveforms). Don't worry about the time, I now have enough time in it that I must carry on. I will try to keep a stiff upper lip! See post 185 for what the sample waveform should look like.
                At the moment I am at a loss as to what to do other than trying another 40106. I spent some time looking at your top and board pictures and they look fine. unless you can take even better pictures we are stuck there. It is possible that I could be missing something because I can not read or test resistor/cap values. We could try an in-circuit measurement of the board with the 40106 removed, if you are up to it.
                Also, still need to measure the regulator outputs 78L05- 79L05 out pins relative to ground. Use your multimeter but be careful not to short the output.
                I also suggest you charge your battery, it is getting low.
                • Old cart thank you, and out of curiosity i had a look at pin6 of the 5534 and this is what i got since playing with the soldering.
                  • Impulse, after having a look at the copper side of your pcb, the first thing I would be doing is cleaning the flux off
                    by useing a soft brush and denatured alcohol, IE methylated spirits let dry and clean again any remaining residue, a clean pcb is a happy pcb
                    thick flux can sometimes do strange things on PI's
                    • 6666, ok i will clean as best i can i have some rosin solvant i use
                      i have put CH1 and 2 on the output of 78l05 and 79l05 and this is what i got ?
Name:	78l05 79l05 output.jpg
                        here [ATTACH]35383[/ATTACH]
                        Actually I meant MULTIMETER.
                        • ahhhh i c sorry! ok 5.067v78l05 5.020v79l05 batt 11.45v
                          • Impulse those look good. It would not hurt to charge the battery.
                              here [ATTACH]35382[/ATTACH]
                              This looks like the damping resistor has either burned up or become unsoldered.:<(
                              Looks like you also went back to using x1-GOOD SHOW, you are learning! I thought the x10 was causing loading problems. It was not and making the signal smaller only succeeded in adding more noise.
                              • ok i have measured the damping resistor and i get 2.1ohm (AH!!!!) i will replace it once i get a new soldering iron as my last one no longer functions as it should (should be tomorrow)
                                is this one ok ? https://www.machinemart.co.uk/p/drap...ering-station/
