ahh now i know what you mean sorry i thought i was missing something, yep no delay between the signals. I have looked at post 210 and all the components are in the correct place. i have a spare 10k pot i can put across the external delay pot connections?
Barracuda Legend Kit Problems
Originally posted by Impulse View Postahh now i know what you mean sorry i thought i was missing something, yep no delay between the signals. I have looked at post 210 and all the components are in the correct place. i have a spare 10k pot i can put across the external delay pot connections?
The 10K pot you have will work great, just set it for max resistance between the center pin and the left pin as viewed with the pins facing down. If you get this correct clockwise rotation of the pot should increase the resistance and the delay. This is the OPPOSITE of the trimmer where clockwise rotation decrease the delay which is illogical and confusing. Then cut the delay pot Link on the board with a sharp knife a measure between the two PCB pads to ensure you have cut it. Lastly solder the two wire from the 10 k external pot. And take traces at pins 2 and 4.
Make sure you are clear what trace ( Link) to cut before doing it. Ask if this is not clear.
Originally posted by kt315 View PostYou do not see THE DELAY between THE signals (the samples' strobes).
Originally posted by Old cart View PostKT 315 So there is about a 200 uS delay between the 2 strobes? You did not state the time per div and volt per div.
Thanks for you help!
take attention 'zero/ground/GND' is a top of the signals just cause 40106 supplies from GND and -E (look at my first pic).
14 pin, plus pin, stay on GND; 7 pin stay on -E.
Originally posted by Impulse View Postok i have CUT the link and put the 10k pot in its place
here [ATTACH]35414[/ATTACH]
Originally posted by kt315 View Posthttp://storage4.static.itmages.ru/i/...19e4cc22d4.jpg
ok i have just tried an air test with a gold ring and i get a positive 6" BEEP then after that it is faint but i still cannot move it around, i have the delay trim set at 10k ohms and the delay trim pot at full (10k ohm)
old cart i do not have a 1uf cap that i can solder to pins 7 and 14
