Baracuda + Micro
  • #91
    Hi Mike
    For menu items you might consider;
    Transmit pulse rate in pulses per second
    Transmit pulse width in usec
    Receive window delay time in usec
    Receive window width in usec
    All within some suitable time limits.
    Chet
    • #92
      Hi Mike
      Chet
      First we need to decide the main menus options and what options go under each of these menus...
      Also, do we use a 16 or 20 character LCD or even look at one of the less expensive (but good quality) TFT displays...
      Mike...
      • #93
        Do you consider adding options for volume, threshold, with digital potentiometers, maybe.
        If you know C, javascript and php may seem easy but doesn't go the other way around, trust me
        • #94
          Mike...
          2.4" TFT with touch and micro SD are cheap (~10euros) and available. I have few. But so far i managed only to use TFT part while am struggling with touch and micro SD reader, can't find proper libraries. That TFT seems is not the same one sold by Adafruit which is well supported with libraries.
          When i try to use those libs; i get inversed touch behavior. I tried to mess into lib parameters, but so far i got nowhere.
          But anyway, similar one sold by Adafruit is just right and well supported. So since it is also having touch; there is no need for physical knobs and pots.
          That would be indeed splendid to use one of those.
          • #95
            Arduino UNO lacks on sufficient I/O once TFT shield is attached on it.
            That's why i used MEGA which is having more than enough I/O's.
            But also i was thinking to adapt TFT shield to use it with UNO, simply by desoldering and rejecting micro SD from it.
            Would it be enough for similar PI detector? All depends on how code is written.
            Further if i give up from touch; more I/O's are salvaged, should be enough for detector.
            TFT color display is just nice, but also it's kind a stupid to use it without touch.
            • #96
              A good daylight display is needed; but a touch screen might not hold up well against muddy fingers.
              Chet
              • #97
                I have used the 1.8" and 2.2" in projects, and even have a 2.2" touch screen laying around somewhere... never got around to playing with it though...
                I bought the 1.8" from Adafruit and the 2.2" on Ebay... tried several libraries with both and after a bit of fidgeting, finally got the 2.2" working and it only cost $6 and has SPI...
                Even without touch both of these would make you think twice before using an ordinary LCD... But... I think for general development we best stick with a 20 character 2 line LCD and build an nice TFT as an option and possibly touch screen if you can get one with SPI/I2C, otherwise we don't have the pins...
                I suppose this design could be built as an Arduino Shield, never thought of that... you would probably have to do an SMD version...
                Back to designing little pulse icons for the LCD...
                Mike
                • #98
                  Chet
                  A valid point... the TFT's I played with are quite bright... possibly as good as any LCD but to being robust... don't think so...
                  • #99
                    I suppose this design could be built as an Arduino Shield... never thought of that...
                    Back to design little pulse icons for the LCD...
                    Mike
                    "...Even without touch both of these would make you think twice before using an ordinary LCD..."
                    Correct! That's why i vote for TFT.
                    • Originally posted by Michaelo View Post
                      My TFT also very bright. Nothing worse than LCD.
                      And if touch is omitted than no problems with dirty fingers.
                      But than physical knobs&pots are necessary...
                      • How about OLED 128x64
                        https://github.com/adafruit/Adafruit_SSD1306
                        http://www.ebay.com/itm/0-96-I2C-IIC...gAAOxy63FS~341
                          Could be an idea... wouldn't add much code...how much is one of those digital potentiometers devices...
                          Re the "other way round"... I never thought of that, but in hindsight, your dead right...
                          C was far more difficult to master and after it, php would be easy but the other way round... I don't think so...
                          Mike
                            Mike
                            Under $1, see hier.
                            You'll need the I2C o SPI protocol.
                            • An OLED would be nice but they are tiny and I already need to wear two pair of glasses to read component markings...
                              Wonder if a bigger one is available for small money?
                              • Originally posted by Teleno View Post
                                Under $1, see hier.
                                Right... advice time... which protocol to use...
                                Mike
