Barauda upgrade???
  • Barauda upgrade???
    Following Qiaozi fix explain from post 102...
    http://www.geotech1.com/forums/showt...it-Rev2)/page5
    Already test it and work, no more swing beep, only tilt.
    Please check if I already on the right path.
    Btw, its working only at day not at night, maybe there is interferences device turn on at night and make beep beep beep.
    https://youtu.be/xEMomBOjxMU
    Still using bf245 as 2n5485 and 2x mpf102
    hello ripsdevala,
    seems like sprint layout, additionel Connections are good upgrade
    can you post sprinlayout file as zip Container or so?
    i have also some boards here will add the upgrade, thx
      Sorry wrong jumper
      Sprit
      CUDACUDA.lay6.zip
      Ignore bc547 circuit its just a batt addon for pcb empty space and i change the order of threshold resistor
        Look at the Geotech Baracuda project thread, where you will find the Build Document and schematic ->Geotech Baracuda
        All the required fixes are listed in the Build Document.
          Yes, already use it, not finish yet, the 40106 track is change alot, so different with the last one
            [QUOTE=ripsdevala;222069]Sorry wrong jumper
            hello ripsdevala! does this changes follows schematic of the upgraded geotech barracuda??
              No its not, im following Q at post 102
              Geo baracuda have different track, especially from 40106
                Does it completely eliminate the end beeping problem as what other have trouble? I want to make one to look the difference.
                  Swing beep is gone, beep only when you shake it up and down, let me test again to make sure.
                    Jladre, swing beep is gone, its beep only when you shake turn.
                    Try mod your baracuda board, and add a new 40106
                      Thank you ripsdevala!��
                        That's because the mods improve the Earth Field elimination. The beep when shaking is probably caused by a loose connection in the coil, or a poor shield in the connecting cable.
                          Done modifying my board. Its working great than before...thanks
                            Hahaha..my board die after few days.. need more time to figure it out why..
                              I m fine with that layout, my friend using it also..., im using LT1054 as 7660S
