Step 7 question
  • Step 7 question
    Hi!
    I am on step 7 of the kit (so far works) and I am not sure whether to continue or not.
    R14 does not seem to change at all apart from a slight change in the faint hum coming off the coil.
    Could I have possible got the wrong pot in place (20k in 100k)?
    The top of the pot in r14 has 306E w 203.
    here is a picture of the board.
    http://i.imgur.com/xK8P1Bu.jpg
    Anything wrong?
    For some reason a different picture is showing even though I uploaded the newer one.
    Originally posted by omr255 View Post
    Hi!
    Anything wrong?
    Edit* Fixed.
      Hi!
      Anything wrong?
      Have you checked this ?> "Make sure you attach your coil and short pin2 of PL2 to either pin 1 or pin 3 (before adjusting R14) otherwise the
      voltage will not change."
        warning, it seems one of the pins 1 or 3 is not connected to ground on the pcb.
          It's strange that no-one has noticed this before. The lower pin of P2 is unconnected. I will add that to the "Updates and Corrections" on the Project Details page.
            Yes I have.
            I get a reading pf -2.13 volts on u7 pin 1 when i short pl2 pin 2 and 3 but nothing when I short it with pin 1.
            Also there is no voltage change on u7 pin 1 when a metal object gets close.
              What is the PL2 ?
                Yes I have.
                Yes, PL2 pin 2 needs to be connected to pin1 to run the test. See post #5.
                Did all the previous tests pass ok, and do you have an oscilloscope?
                  What is the PL2 ?
                  PL2 is the 3-pin connector for the sample delay pot.
                    Yes all previous tests have passed with success. I do not happen to have an osscilloscope. The IRF does get a bit hot.
                      Any diagnosis?
                        The MOSFET should not be getting hot. Are you sure that the coil is ok, and the TX oscillator is working?
                          And what answers do you bring to this tread ?
                          http://www.geotech1.com/forums/showt...rracuda-HELP!!
                            The speaker makes a low tone sound when connected to u4 pin 4 and the coil is 20 turns of .5mm copper wire of around 20cm diameter.
                              The coil is exactly 27cm in diameter.
