There's not current without the coil in place. What is the Resistance and Inductance of the coil ?
Step 7 question
Originally posted by Qiaozhi View PostC7, C10, C11, C12, C13, C14 and C21 are all the wrong values in your photo.
None of these are polarity sensitive.
Update: OK - I see that you've now changed those in your latest photo.
There must be something else wrong that's not obvious by looking at it. I can assure you that this design works exactly as described, so you must an error somewhere. It's very difficult to debug remotely and without a scope.
Could it be one of the ic chips, fets or voltage regulators that are malfunctioning?
Originally posted by omr255 View Post
Did you not read the instructions where it says: "One common mistake is to enter the diameter of the coil, instead of the radius, into the first field of the dialog box."?
I know some people believe that they've failed if they have to read the instructions, but so far you're managing to disprove that theory.
Originally posted by Qiaozhi View PostAs chevesne has pointed out, it appears from the Coil Calculator that your coil diameter is 520mm.
The lf412 seems to be working again.
I have made a 24 turn 13cm radius coil from .5 mm wire and now the mosfet gets a tiny bit warm to the touch.
But I still can not get the voltage on u7 pin 1 to change by turning r14.
