setup procedure from Geotech Baracuda pdf?
  • setup procedure from Geotech Baracuda pdf?
    Hello people,
    can I use the setup procedure from "Building the Geotech Baracuda (Rev-A) .pdf" for this version of baracuda v2 from silverdog?
    Thanks.
    Originally posted by Psyborg View Post
    Hello people,
    Thanks.
    What do you mean by "for this version of baracuda v2"?
    Did you purchase the PCB from Silverdog, and does it say "Geotech Baracuda REV-A" on the board?
      If you make the coil close to the original you don't have to worry about tuning the damping resistor
      if you've got a scope set the offset to zero volts.
      the delay is trial by error. What ever you set it to is a comprise. Best for a gold ring is terrible on some copper alloy. Best to get a selection of what you hope to find and find a happy medium. Long delay gives some iron discrimination but rubbish on a gold ring. Best on a gold ring knocks a roman brooch by half. I found best distance on my roman fibular was a nice compromise for me.
      Not not that I have ever used it on the beach. Mostly done fields lately.
        It is old one, silverdogs kit rev2.
          In that case, you cannot use the Geotech Baracuda Rev-A Build Document.
          However, it is worth reading, as you will then be aware of the problems existing in the V2 design.
