BARACUDA-Legend-1
  • converting to pdf format . or lay. to make pcb
    • Originally posted by pito View Post
      I have a problem converting the Gerber files of this circuit. = converting to ???
      converting to pdf format . or lay. to make pcb​
      • Gerber files of this circuit = so you have Gerber files ?
        • Originally posted by arlim View Post
          Has anyone made the Geotech Baracuda - REV-A? If someone made this circuit, please explain if it detects gold and silver or not? In the circuit that I made, most metals are easily sensed except for gold and silver. Mr. Qiaozhi I would be glad if you could guide me on this. Does the circuit you optimized sense the gold? Thankful
          What do you mean by "Does the circuit you optimized sense the gold"?
          If you mean "gold nuggets" then note on page 18 of the Build Document that it says:
          "The preamp is a standard single-stage design with a gain of 1000 (60dB). This detector is designed
          for use on the beach, and (if constructed in a waterproof enclosure) for shallow diving. It is not
          designed for gold nugget hunting
            Hello to all. I made the barracuda circuit and it works great. I decided to make Barracuda Geotech as well. I designed a PCB for it, which I put below. This circuit also works great, but it doesn't find the gold and silver. Can anyone tell me why?[ATTACH]58049[/ATTACH][ATTACH]58050[/ATTACH][ATTACH]58051[/ATTACH]
            If your circuit works but can not find the gold or silver then maybe there is no gold or silver...
              George's Bara files are free of a charge.
                hi kt315
                can i use this oscilloscope for this bara
                • can we use this power schematic
                  • Originally posted by Deghbar613 View Post
                    hi kt315
                    you can use any o-scope but must remember on the coil you have high voltage pulse, 150-200V p-p. so you may burn o-scope if touch 'hot' end.
                    you have to know o-scope specs.
                      Click image for larger version  Name:	Schematic_withe_idxpro_2025-01-13.png Views:	25 Size:	16.3 KB ID:	432924
                      This circuit will not work... Better google it again to see how to draw the circuit correct.
                      • Or use this one...
Name:	Simple Power Supply.png
                          Click image for larger version  Name:	Schematic_withe_idxpro_2025-01-13.png Views:	50 Size:	16.3 KB ID:	432924
                          not. if be sure. it's primitive way. oldest and uneffective. you have to see in a side of impulse converter, buy from chineses. they may be also bipolar.
                          look STEP UP CONVERTER and choice looking the current/power you need.
                            please kt315 what's rule of this pin in picture
Name:	Geotech Baracuda - Schematic (2).jpg
                            • this is some kinda 'synchronization' of the U5 for serving decrease a noise of U5 in circiut, on time of TX pulse.
                                thank you so much
