BARACUDA-Legend-1
  • hello everyone
    what makes lf9540 so so so hot
    please any idea
    • Hi,
      the TX-pulse width is probably not correkt or you have a fake IRF MosFet from China.
      • you do not have a signal (impulse) on the Gate of mos-fet. why you write LF9540?
          sorry kt315 tired mistake irf9540
            how it look like TX-pulse width?
            • Originally posted by Deghbar613 View Post
              This some info from oscilloscope
              this irf9540 gate
              Click image for larger version  Name:	20250429_190007.jpg Views:	0 Size:	586.1 KB ID:	437079
              This coil
              Click image for larger version  Name:	20250429_190147.jpg Views:	0 Size:	547.1 KB ID:	437080
              • ok. you changed IRF9640, that is clear noted in the schematic, on IRF9540. while 9540 is 100V max, 9640 is 200V.
                and you sure get the zener effect this heat out on the cutoff above 100V pp.
                • Your waveforms look normal. The PMOS is supposed to get fairly hot because it avalanches during turn-off. Many PI designs even add a heat sink. It looks like your TX pulse width is 150us; one thing you can try is reducing it to 100us or even 50us and see if it runs cooler. If it does, then everything is probably OK.
                    How can i reducing TX pulse with ?
                    • Thx kt315 AND carl-NC and everyone who help
                        I'm not familiar with how the circuit works, but it looks l to me that U4a and U4b create the TX pulse so I would alter the R & C values around them to see what happens. In particular, I would start with R10 & R11.
                        • thx carl it works now irf9540 just worm
                          • Hello everyone any help
                            my flyback signal is crazy not stable where is the problem
                            • put o-scope probe on output of preamp/op amp and do video again. i see you want to burn o-scope by the HV signal.
                                Hi kt315 this video for U2 pin6
                                about HV signal i am using X10 probe i think o-scope is safe
