BARACUDA-Legend-1
  • Tried something different. I replaced the NE5534 with a LT1115 that I happened to have around and noticed a nice depth increase, especially on gold objects. Cuda also ran smoother and quietier. Anybody else try this?
    • Hi Grant
      great news i have got one of your boards to work
      after fixing the solder blob
      i could not figure out what was dragging down the -5 volt rail
      turned out the 40106 chip was doing some weird things to the
      -5 volt rail , replaced it and it now working
      now i need to make you a new coil
        Hi Grant
        Excellent, thank you for all your efforts it is greatly appreciated.
        • BARACUDA KITS
          HELLO from ARIZONA...and MERRY CHRISTMAS
          I,m interested in a kit for the BARACUDA
          How much????
          I dont have the resources to make boards yet
          • Originally posted by area5.1 View Post
            How much????
            http://www.silverdog.co.uk/shop/inde...product_id=105
            • Thank U for a quick reply.
              Is that price in american dollars?
              • No it's in British Pounds. Contact him and he will give you a price in $!!!!
                  If you pay by PayPal, the conversion is done as part of the transaction.
                  • Hi all
                    I wonder if any body could help me to get Baracouda schematic by Eagle pcb
                    I would be grateful
                    • I Have build the Barracuda i Have Questions
                      First my Barra is running i Have 30 cm on a 1 Euro Coin and my Wifes small Goldring on 27 cm with a 216 mm Coil 0,5mm enameled Copper and 22 Turns, all in Air.I will build more Coils but in Germany you find only 23 Meters of 0,5 Copper can i Build with 0,6 mm? and have anybody a "recipe"for a 270 mm Coil with 0,6mm or 0,5 mm (but better with 0,6 mm) Thank you excuse my english i am German with only school english
                      • hi vermeer
                        try this http://www.spulen.com/shop/index.php...ort=2a&&page=5
                        (best prices)
                        or this
                        http://www.ebay.de/itm/Rest-H05V-K-L...item5891aff5ed
                        or a smaller diameter
                        liy litz wire type (my fovourite)
                        greetings from Berlin
                        • exactly this is was iam searching for thank you my detector have the "second delay" i mean the 10 k fine Ponti,i have tested without this my detecting was poor with this (proper setting) my detecting was very good 30 cm 1 euro with 216 mm coil and a small gold ring 27 cm in air is this normal greetings from the harz forrest
                          • detection range is ok for you coil
                            but normally you dont need the fine tuninh delay pot
                            use a multiturn pot or multiturn trimmer
                            so you can fine adjust easy
                            regards bernd
                            • normaly yes but by my machine i have tested with the "extra pot" an without,without the extra pot i have poor detection range so 20 cm on 1 euro coin and then with this pot (10 k fine delay) with sw 1 on,treshold in the middle,10 k fine delay 0 ohm,25 k delay on the board adjust that the tone go to silence then sw 1 open and adjust 10 k pot fine delay to the best detection range,30 cm a 1 euro and the small gold ring from my wife 27 cm in air without this only 20 cm 1 euro and 10-12 cm the gold ring all with a shielded coil 216 mm 0,5 mm enameled copper wire 22 turns i have brought the set from silverdog a wonderful kit only i have a faulty 7660 substitute this with a good one and all is running.
                                regards bernd
                                Hi
                                I would be grateful
