BARACUDA-Legend-1
  • ant, wilson is right 40106, ne5534 and lf412 need need to be tested/replaced, the best advice is to do them one at a time rather than all at once, so you can trace the problem.
    the chip sockets idea is also very good advice, you can always remove them as final task when you finish(if you like your chips hard soldered),
    i have never been convinced it matters, what matters more is the quality of the sockets.
    even the cheapest sockets will work for your task,when you have 4 chips that work and you have basic function you can remove them and install the working chips permanently.
    • i do that right now
      • Originally posted by sinclairuser View Post
        i just found the problem after so many hours it is working no heat anymore in 7660 dead cold it was a short circuit in pcb .....my god!!!!i need some sleep .but i have two questions when i turn the swicth on i mesure the frequency from the output were the coil is for and is stable when i turn the thershold pot it is changing the frequency is this write???and the second question is the 2 trimmer 22k wich potision is write to put it how many kohm?
          To eliminate the effect of the Earth's magnetic field, you will need to add a secondary pulse sample (taken much later in the pulse decay cycle) and subtract this from the main sample. Have a look at the Hammerhead article.
          it is good to descharge the ground using an 220volt inverter conected to ground for 5 minute after that use your detector no entefirince no earth magnetic fields!!!
          • Originally posted by antonioknight View Post
            A . C . POWER DECHARGE EVERYTHING
            • MY baracuda legend is firing up Woop Woop .
              Okay BIG thank you to Bob the Man I love you top man very helpful and help got my DM working.
              I must say that if there is anyone out there with a baracuda which is not working the chances are its the same problem I had.
              All I did was blow the little speaker that came with my kit and it was shorting the audio circuit hence stopping any sound hay take a look you never know remove it and wire in a small set of cheap ear phones to carry out the test best of luck DUDS.....
              • THANK YOU
                THANK YOU WILSON ,sinclairuser AND OTHER MEMBERS OF GEOTECH MY BARRA WORKS FINE I MADE 16 INCH COIL WITH 1.4 OHM RESISTANCE THANK YOU EVERYONE
                • antonio please make a testing hour and check all pcb components on the coil section and lok if they get hot (damping resistor, tip127...)
                  • Well done Sinclair
                    I also have some very good results and will update you soon with some tips that are useful plus pictures.
                    Best results with 1.5" coil is 4" depth 18ct thin lady's ring and 5" for pre 37 old sixpence which is amazing considering it was made round a toilet roll with old alarm wire.
                    • Hello Wilson. At several places in the forum you write that you made ​​modifications in the scheme. I look at the photos in posts 725 + 750 and next to a LED I see diode 4148, which I think is reversed. Is this one of modifications, you're talking about?
                      • Im building a Baracuda kit from Silverdog, what is the SPST switch for? and where does it attach?
                        Also If I want to add a delay pot, where does this attach to on the board?
                        • Hello Tonyh,
                          Glade to hear your building the Bara, Silverdog's kit is excellent. what I suggest you do is read through all the threads from the start. You'll find the answers to all questions, plus a ton of tips that will help you build a successful sensitive Bara. I built the Bara about a year ago and it works fabulous, a killer beach machine indeed.
                          Best regards,
                          • yes I have read through the thread, there is nowhere on the alex/ap rev2 board to solder the switch to, the delay pot is easier it replaces the link to the right of the delay trimmer.
                            As Q5,R26,R37 and SW1 has been removed from the board, it should really be printed as rev3 not rev2, the rev2 still has these holes in pcb.
                            • Guys, how deep is this detector? Is it better then SURF PI?
                                the standard 7660 cant handle 12v it should be no higher than 11.2 or your just creating heat.
                                if you must use 12v you need the irf fet and 7660a or 7660 sc but even then its just wasted power imho the barracuda was intended to run at 9.6v 8x1.2 AA rechargeable you can use six AA 1.5v high power alkaline giving 9v(thats what i did and it runs fine dont rate rechargeables in detectors that take separate aa cells).
                                pp3 9v batts just dont work well in fact the difference between 2x 9v pp3(9v config) and 6x 1.5 duracell extra were worlds apart in my own tests so i went that route irf fet and 7660a/sc is definatley the way to go as that has the most flexable power range 9v-13v.
                                Hi Sinclair
                                Like yours mine works great with 9v and I agree using 12v is just wasted power as the circuit was never designed for it.
                                Now here is a interesting one... Mine using a pp3 works fine and seems to work endlessly during a few hours of use.
                                The reason for this is proberly because I am using the the TIP127 where as I think the FET draws more current
                                Anyway will do a quick replacment with a fet and see if my findings are correct.
