There was no layout as this was just a proposed mod. Not sure if it has ever been tested...
BARACUDA-Legend-1
Originally posted by FatBob View PostThere was no layout as this was just a proposed mod. Not sure if it has ever been tested...
BUT it is best to wait for the new kit that fixes several problems that at least some, and maybe many, Baracuda's have!
Originally posted by ripsdevala View PostJust some test, when I change 2n2222 with C1815 it doesnt have any different, when I use 28cm 30turn 0.5wire the tip127 not get hot, but the sensitivity is decrease.
the delay and offset will need readjusting for the new coil.
Originally posted by ripsdevala View PostChange TL072 with LM358P LONG BEEP..... AND STOP MAKING A SOUND FROM NOW ON....my bad, what should I do now? Still working tho, the led signal still sens metal object.
try removing the LED and a different speaker.
Thank for the reply, at last someone to share with...
I dont know if 7660 have max v10, is that ok? Just order 7660S 12v max.
Originally posted by Koala View Postdouble check as was working up to this point.
