BARACUDA-Legend-1
  • Originally posted by Koala View Post
    Mohandes looks like your detector is working well.
    thanks
    but it is not work same dp2 or psg.what the diff?or it is normal?
    dp2 is deeper and very good for depth detection ,barra work for detect coin ?
    • Originally posted by mohandes View Post
      thanks
      Does TIP127 stay warm or get very hot
      Adjust offset for best results does not have to be 0V
      Also adjust delay for best performance on small gold
      Yes when set up it will detect a coin great
      Will never be as deep as the delta pulse
        no not warm at all.
        i have not scope yet.so can not adjust
        again not adjust but in max depth maybe set it ok
        • No scope needed
          trial and error is best for this detector
          Gold is best for testing I used a ladies ring.
          Takes a bit of messing around to get the best performance.
          I have not tried different coils and damping resistors on mine yet.
            No scope needed
            delay for dp2 is 23mks,so for gold detection more, so i decrease it to 10mks.and what about barra?
            i have 2 detector and test them, work by barra is very easy,but not power like dp2.
            know i search for pi with disc, how ever i buy 3 pic28f252 for dp2 and very good work.
            • Hello friends, I still can not run. Now at least I have sound. I have tresh varying volume, but no variation by bringing a metal to coil.
              current coil: 20cm 0.5mm 20 laps. copper
              thanks
              • I have been lurking for awhile. Very interesting. Great work everyone.
                • Hello all. I have redrawn Alexismex hand schematic in pdf format. I would like to share with everyone. Can someone kindly tell me how can I?
                  Thank you
                  • Click on "Reply". Then click on the "Go Advanced" tab at the bottom. From there the user options are expanded, and looking you will see the little "paperclip icon". From there you can attach files .... (can be pdf jpeg gif etc)
                    • Schematic for Baracuda
                      Thank you Greylourie
                      • Baracuda Schematic
                        Here is the schematic from Alexismex in pdf.
                        • Surf Master PI and BARACUDA work absolute one
                          the same principle. Their means of its implementation
                          differ slightly. BARACUDA.rar contain
                          files, by means of which can be made
                          BARACUDA in the clothes of Surf Master PI, a patch of
                          HAMMERHEAD. The management of the device is
                          performed by controller 12F683. HEX-code
                          BARACUDA.HEX determined the transmitter frequency
                          640Hz, the transmitter pulse duration
                          100uS, SAMPLE1 and SAMPLE2 45uS,
                          SAMPLE1 delay 5-50uS, SAMPLE SPREAD 210uS.
                          https://www.dropbox.com/s/01dtn4gznj8pjcv/BARACUDA.rar?dl=0
                          • Very nice schematic layout. Thanks. I wonder why the power switch is always in the ground path rather than the hot side? It seems that putting it on the hot side would make for a lower impedance ground path which is good thing.
                            • In BARACUDA so.
                              • Anyone can tell how to add volume control here, thank you.
