Beachmaster Digital
  • Originally posted by Olly View Post
    I believe that the basic pulse induction part of the detector is working well enough to realease the experimental code of the system so far.
    Please note that this is experimental code only and may still include some bugs which I'll hopefully iron out as I progress.
    Discrimination with the Induction Balance receive coil is not supported yet, this is what I'll be working on next.
    Also not yet included is any form of slope detection on the Pulse Induction side, I will look into this at a later stage.
    [ATTACH]57867[/ATTACH]
    The 'beachmaster.uf2' file in the 'build' sub-directory is the programming file already compiled and ready to drop into the Raspberry Pi Pico.
    If you wish to setup your computer system to compile your own then the source code is ready to do so, you'll just need to follow the guidelines as per the documentation at the following link: -
    https://datasheets.raspberrypi.com/p...-with-pico.pdf
    I was waiting for it, thank you. I hope the project will go well
    • Comment
