Beachmaster Digital
    Originally posted by jeep6789 View Post
    I can't understand + 8V, is it from the second section 18650? In this case, it will cause the battery's imbalance.
    The intended power supply for the detector is via 5 x 18650 LiIon Cells.
    3 cells in series to give a nominal -12V and 2 cells in series to give a nominal +8V.
    I'm doing it this way rather than the traditional approach of using a charge pump for two reasons: -
    a) The current requirements of the Raspberry Pi Pico and LCD combination approach the max possible from a charge pump.
    b) We eliminate the switching noise from the charge pump.
    It is possible that current drain through the +8V and -12V segments won't balance and one of them will get flat before the other, which is why I have provided ADC monitoring of both levels so that the CPU can take the necesarry steps to warn the user and protect the batteries.
    My intention is to have a separate battery pack mounted under the cuff with a 2-pole switch powering the detector.
    I also intend to have a multi-way connector on the battery pack in order to balance charge the cells without having to remove them. (A multi-cell balance charger as used for model aircraft is ideal for this and I have a few kicking around).
    Hope this helps,
      That sounds like a good plan for the batteries.
      Yes, one of the battery sets will discharge before the other but since you have monitoring of each the lowest one sets the time to stop detecting.
      A Balance charger is then needed to properly put the juice back.
      thanks for the mpc33131 date sheet. Should do the job if the PI_pico can do the SPI fast enough.
      I have played with using a PIC32 with a fast ADC to sample the coil decay waveform. Found I needed to sum multiple decay cycles to beat the noise down. This worked well since the Coil pulsing ran at 1.6kHz but only needed to update to the audio/display at 30Hz so lots of time to get multiply samples and do the math.
      When you do the PCB be careful of Currents flowing in the ground plane. A single solid plane is not the best way to go. Ensure that the current in the coil switching does not go into the analog circuits. Keep these two plane areas separate then tied together at ONE POINT (near the battery.
        Thanks for the tips Waltr, I will certainly take great care with the grounding and component placement to minimise large circulating currents.
        The RP Pico has programmable PIO's and DMA which I plan to use for the ADC SPI. This way I can easily get the data in and stored away in RAM without any intervention from the main program. It also has two cores each running at 125MHz (or 133MHz with a bit of overclocking - but I don't normally use this) for when I need to process the results.
        I agree that a bit of oversampling is required to bump the noise down. 16x should give 12dB noise reduction.
        My plan is as follows: -
        At the falling edge of the TX pulse take 64 samples at 1uSec intervals and DMA the results to RAM.
        Do this every falling edge and add the results to an array such that we have a 16x rolling average of each of the 64 points on the decay curve.
        We should have more than enough horsepower in the Pico to do this as well as enough RAM (16 x 64 x 2) bytes = 2K. (The Pico has 264K internal RAM and 2M for program storage)
        This should leave us with a nice clean decay curve representation for analysis.
        Cheers
          I think 7905 should be replaced with low noise LDO because it has a large noise, less than 16 precision.
            I think we'll be OK - the L79L05 has 40uV output noise, but the LT6200 has 68dB PSRR which is around 2500x so even at the 1000x gain of the 2 x LT6200's the output noise as a result of the L79L05 will be 40uV/2500 X 1000 which is only 16uV.
            All things being perfect the bit resoltion of a 16-bit ADC with 5V reference is 5/2^16 = 76uV, so more than 4x the noise from the L79L05.
            If this was our only noise source I might consider attending to it, however the Johnson noise from the 1K resistor R14 amplified by 1000x is orders of magnitude greater so in essence the supply noise is not an issue.
            Kind regards
              Ok, thank you for explanation, in all PI detectors, why everyone likes to use D ? 5V to supply the op amp supply, why not directly use 3.3V to provide power supply? 6200 lowest voltage is 2.5V, If we use 3.3V power, can this?
                There is also a very important issue, 12V in the circuit. No voltage regulation, will not affect the stability of the machine when using
                  In general better SNR is achieved with higher supply voltages and most opamps don't swing rail-to-rail so +/- 5V gives a bit of headroom.
                  In this specific design, I need the +5V to match the amplifier output to the 5V range of the ADC.
                    The -12V is only used directly by the PI coil, all critical supplies are regulated.
                    It is a fact that as the battery supply drops then the TX current achieved for a specific pulse width will drop slightly, but this is easily compensated for by automatically increasing pulse width according to monitored voltage.
                      You are really very powerful
                        You can let everyone learn a lot, I want to know why choose to detect communication, not by electronic switch, integrator detection DC, is it to simplify the circuit? Can you tell you what kind of aspects should be written from?
                          I'm sorry, I don't understand the question ???
                            Your ADC detects an AC signal, why not choose to detect DC signals?
                              Ah, I think I understand what you're asking! You want to know why I'm sampling the flyback pulse directly rather than sampling the integrated flyback window.
                              What I'm trying to do is to get an idea of the flyback slope and to then hopefully extract some indication of the target tau. With this information combined with the RX coil's amplitude and phase, I'm hoping to perform rudimentary discrimination.
                              If you check out George Overton's book on the "Voodoo" project it gives an enormous amount of information on this technique which he pioneered. I'm trying to do something similar but with direct sampling.
                                Good, you will be satisfactory
