IB Metal Detector Project, Part 27
  • IB Metal Detector Project, Part 27
    For completeness here is count2200 which is the last of the high speed code.
    This routine counts to see if it is time for the slow speed code. If it is, it copies the contents of the accumulators to a safe location and clears the accumulators. After that it is safe to re-enable the timer 2 interrupt. We are still inside the timer 2 interrupt routine, but we will not be using the high speed variables so it is safe to allow this part of the code to be interrupted. In fact it is necessary because the slow speed routines are going to take a lot longer than one quarter cycle to complete.
    Robert Hoolko
    count2200:
    ; Update counters
    ; Count 2200ths of a sec
    ; and call the slow loop routines if it is time
    ; Registers r16 r17 r18 Z are free
    lds r16,c2200
    inc r16 ; 2200dths
    sts c2200,r16
    cpi r16,74 ; 74 = 30 Hz
    breq cntslow ;
    ret
    ; We are now in the slow loop, 30 Hz
    cntslow:
    clr r16
    sts c2200,r16 ; clear counter
    lds r16,Iaccum ; copy accumulated data I
    lds r17,Iaccum+1
    lds r18,Iaccum+2
    sts Ihold,r16
    sts Ihold+1,r17
    sts Ihold+2,r18
    lds r16,Qaccum ; copy accumulated data Q
    lds r17,Qaccum+1
    lds r18,Qaccum+2
    sts Qhold,r16
    sts Qhold+1,r17
    sts Qhold+2,r18
    clr r16
    sts Iaccum,r16 ; clear accumulators
    sts Iaccum+1,r16
    sts Iaccum+2,r16
    sts Qaccum,r16
    sts Qaccum+1,r16
    sts Qaccum+2,r16
    ; It is now safe to allow the T2
    sei ; interrupt to occur again
    rcall Islow ; go do the slow routines
    ret
