Works now thanks
The Moodz detector lives !
... thanks for all comments ... the current design only has one channel ( or two depending on your point of view ) ... was not expecting the discrimination frontend to work so well for this version. With "one" channel I can sample X or R or some subtractive combination ... however any sort of subtraction is probably going to leave a target hole. So I am leaning towards two tone .... one tone ( channel X ) for X and one tone ( channel R ) for R similiar to some VLF detectors ... will this be effective ?
Will need to add the additional channel hardware to the design at any rate...( re-lay the PCB ) .... maybe the handling of X and R can be user configurable ?
The current design is surface mount ... makes the PCB cheaper but trickier assembly for some constructors ?
Probably should also note that gains in the signal chain are only set to 20% of potential and timings are also conservative ... could decrease sampling time by 60% at least ( sub 3 us ?) for very small targets.
Hot ground and salt water tests for discrimination ?? May need DD coil / fig 8 coil ?? Change sampling or gain ?? Cant answer just yet.
DD coils etc ...?? Only tested for MONO coils ( I like mono coils ;-) because they are "pure" coils ) ... however need to add additional channel(s) to board for these also ??
moodz
Hi Moodz
I am very impressed with your detector. And appreciate you sharing it with us. I offer the following comments in reply to your questions:
“... thanks for all comments ... the current design only has one channel ( or two depending on your point of view ) ... was not expecting the discrimination frontend to work so well for this version. With "one" channel I can sample X or R or some subtractive combination ... however any sort of subtraction is probably going to leave a target hole. So I am leaning towards two tone .... one tone ( channel X ) for X and one tone ( channel R ) for R similar to some VLF detectors ... will this be effective ?”
If there is a target hole could the position be selected or movable by the builder? Discrimination is never fool proof because of size, shape and different target time constants for the same metal. I think the tone option would be the most effective.
“Will need to add the additional channel hardware to the design at any rate...( re-lay the PCB ) .... maybe the handling of X and R can be user configurable ?”
If possible I think having an all metal option dependent on the builder’s choice is a good way to go.
“The current design is surface mount ... makes the PCB cheaper but trickier assembly for some constructors ?”
This is probably the most important decision to make. For some of us surface mount is just not doable. For me Carl’s Hammer Head surface mount board was beyond my capability. Any mistake or repair or design change sometimes leads to starting over with a new board and new components. If you can see your way to providing a standard through the hole board I believe it will please many of us.
“Probably should also note that gains in the signal chain are only set to 20% of potential and timings are also conservative ... could decrease sampling time by 60% at least ( sub 3 us ?) for very small targets.”
I think providing build options such as different resistor values to adjust gains and sample times is a benefit. Having the ability to sample as early as 3us is fantastic for gold hunters.
“Hot ground and salt water tests for discrimination ?? May need DD coil / fig 8 coil ?? Change sampling or gain ?? Cant answer just yet.
DD coils etc ...?? Only tested for MONO coils ( I like mono coils ;-) because they are "pure" coils ) ... however need to add additional channel(s) to board for these also ??”
I don’t think an additional channel is needed. A jumper option to use a MONO coil or a coil with a separate receiver winding should be acceptable. This would allow various two coil arrangements to be used. Are you using your differential frontend? It would be useful to use a separate transmitter coil with an isolated separate center tapped receiver coil.
Thank you for sharing this with us and have a great day,
Chet
Discrimination hole may be avoided by toggling two or more ground balanced delays, but there is another catch - a phase reversal beyond hole. If design includes an absolute value circuit - no problem. Otherwise you'll see targets beyond a hole only with phase reversed, i.e. outside the coil loop.
...so I played with the timings a bit and the ferrite rejection is good ( in terms of audio output ... ) and the target sensitivity is still good also.
https://www.youtube.com/watch?v=UHBV2hZrivo
In this video the ferrite is right on the coil ... hence the massive changes in X signal ... however the R signal is still very sensitive.
